NA Headlight Popup Rods
mazdatenfive
Postby mazdatenfive » Sun Mar 06, 2011 11:55 am
Can the rods be removed from the back of the popup lights. I can't get mine off because of the nylon cup surrounding the ball. I want to grease them up or maybe replace them.
tbro
Re: NA Headlight Popup Rods
Postby tbro » Sun Mar 06, 2011 12:20 pm
NA01-51-SA5, rod is replaceable, BUT you will probably stuff em getting them off, the trick is to "flick them off" as you would wiper arm pivots.
May be better injecting lube into joint.
Terry
mazdatenfive
Postby mazdatenfive » Sun Mar 06, 2011 12:53 pm
tbro wrote:NA01-51-SA5, rod is replaceable, BUT you will probably stuff em getting them off, the trick is to "flick them off" as you would wiper arm pivots.
Terry
Do you mean use a lever to pop the ball out of the nylon cup.
Users browsing this forum: No registered users and 83 guests
