What i did on my holidays - or its red again !!
kazjim
Postby kazjim » Sun Jan 30, 2011 5:00 pm
I bought my little Na6 a few years ago with pretty tired paint (well, it was pink on most panels !)
Some nasty fruitbat had deposited a lump on the bonnet and on removing it, a large hole appeared in the paint !! - seems that bad guano rots body filler, who knew ?
The front bar was cracked and nasty looking with peeling clearcoat and basically ugly.
so over xmas i decided to give it a little spruce up...
1 litre of Classic Red was mixed by my friends at Auto-Pro west gosford, and some fibreglass matting was acquired from Glenn at rebel Spares (White Monaro, very nice..)
I'll let the pics tell the rest.
First thing i did was remove the front bar and scuff the paint with 400 wet / dry and plenty of water
The front bar was re-glassed and filled (this is a middle-stage photo, sorry, forgot to take pics at each stage !)
I gave the whole body a rub down with wax and grease remover (Super-cheap auto) and layed 3 light coats of paint (1:1.5 / paint:thinner)
A few more coats and it was starting to look better :) , so i took it outside to harden for a few days (2 weeks it turned out to be thanks to a failed ISCV sensor.. bleurgh)
A little bit of polishing later (try close to 12 hours !!) (large orbital polisher - first time I've ever used one, not too bad if you get your speeds right!)
I suppose the take home story is that an uneducated fool like myself can spray panels, its not perfect, but then again this is my every-day car, and I'm not a spray-painter!
I like how it came out, but ifi was to do it again, I'd use a LOT more paint (about 3 liters i think) and get someone else to polish it !!
If my calculations are correct, when this baby hits eighty-eight miles per hour ... you're gonna see some serious s**t.
Old Dude
Re: What i did on my holidays - or its red again !!
Postby Old Dude » Sun Jan 30, 2011 5:55 pm
nice job Kazjim :beer: :beer: :beer:
MX 5 2001 Grace Green
NB8B
slug_dub
Postby slug_dub » Sun Jan 30, 2011 9:19 pm
Nice work! A great sense of satisfaction in doing it yourself, and you have more confidence to do better next time, I know I do! :)
ForceMajeure
Postby ForceMajeure » Sun Jan 30, 2011 11:33 pm
Nice work mate, dont think Ive seen you around the area, ill keep a look out for the striped NA. 8)
mazdatenfive
Postby mazdatenfive » Mon Jan 31, 2011 11:36 am
All work is preparation, sanding, sanding and then more sanding.
Now you need to clean the wheels!!
Tedsmx5
Vehicle: NA8 - Supercharged
Postby Tedsmx5 » Sat Feb 26, 2011 8:26 pm
To clean all aloy wheels I would use pre-wash spray (the cheap home brand hand pump type) apply spray let it soak in then brush and rinse off. It will kill the lawn :shock: ! So blame the dog for it :lol: . Please try it, takes the brake dust so easy.
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
aviper4u
Postby aviper4u » Tue Mar 01, 2011 7:12 pm
nice result though what paint did you use IE; catalyst OR non catalyst?
kazjim
Postby kazjim » Tue Mar 01, 2011 7:54 pm
It was definitely non-catalyst - i woudnt reccommend ANYONE to spray that stuff at home - use a booth and respirator people !
Pretty sure it was a factory style acrylic, well, thats what i asked for :)
Thanks all, the wheels are nice and clean, and the paint is almost ready for its first major buffing ..... now all i need is a spare few hours to do it in !
J
aviper4u
Postby aviper4u » Wed Mar 02, 2011 11:18 am
good to hear on the non catalyst though what type of cutting compound will you be using? i did some repairs to my paintwork using non catalyst also though was thinking if standard catalyst type buffing compounds were too harsh if theres a difference
also how long were you told to wait to dry before final waxing etc...... i've heard anywhere from 3-6 months
kazjim
Postby kazjim » Wed Mar 02, 2011 2:13 pm
I'm using a meguiars medium cut machine compound .....using a proper orbital polisher (not the $40 super-cheap random orbit ones ...)
Wool pad, set to about 2k rpm, and about 2-3 mls of compound at a time .....
not very harsh, in fact its downright slow ! - but thats ok, the slower it is, the less i take off, right ?
I've been told the same, but its a 'daily street' car and sits in the sun most days, so I'm giving it the final polish and wax this weekend if the weather / time is appropriate.
aviper4u
Postby aviper4u » Wed Mar 02, 2011 2:41 pm
i got that mr buff one which isnt very harsh and 2k rpm etc does take a while, in fact i haven't finished mine 3 months later lol
dont forget to apply a swirl remover / polish after buffing flat and before waxing, you will not be disapointed
deviant
Postby deviant » Wed Mar 02, 2011 2:50 pm
That looks great. You should be pleased with it!
How hard is it to do the stripes? Where did you buy the kit from to do it? I have got a hankering to do the same on my BRG NA but in yellow.
mazdatenfive
Postby mazdatenfive » Thu Mar 03, 2011 7:53 am
Won't be able to miss you now as I cruise the CC.
Users browsing this forum: Google [Bot] and 45 guests
