Looking for NB8B brake pads... which ones?
jdimitri
Postby jdimitri » Thu Feb 24, 2011 8:37 pm
Went to my first track/instructional day today and had loads of fun.
On the way home it was making a funny sound though, had a look and sure enough the front brake pads are gone.
Which ones are recommended for 8Bs? I need it fairly soon because it's my main method of transportation, so maybe somewhere local?
Are the OEM mazda ones fine? How much will they set me back?
The pads on the inside were much more used than the outside. The inside ones were almost bare whereas the outside ones had ~2mm, is this a problem?
Also, how can I tell if the rotors are still fine or will need resurfacing?
Excuse the noob questions, this is one of the first mechanical things I've ever done
Btw I saw a vic club member in a silver NB8B but after that session the car disappeared and I couldn't pick the guy out with his helmet off :|
Caffeine
Re: Looking for NB8B brake pads... which ones?
Postby Caffeine » Fri Feb 25, 2011 8:55 am
About $300ish from Mazda, but Mazda just resell (or did recently) the bendix advance, which were around $70 for a set of fronts.
More high performance offerings such as the Hawk HP+ are around $200
rascal
Postby rascal » Fri Feb 25, 2011 9:00 am
jdimitri wrote:The pads on the inside were much more used than the outside. The inside ones were almost bare whereas the outside ones had ~2mm, is this a problem?
Sounds like your calipers pins need greasing.
de Bounce
Postby de Bounce » Fri Feb 25, 2011 10:01 am
Make sure you use the correct synthetic grease for the slide pin and NOT wheel bearing grease as discussed HERE
Motorkhana Video
jdimitri
Postby jdimitri » Fri Feb 25, 2011 11:11 am
Caffeine wrote:About $300ish from Mazda, but Mazda just resell (or did recently) the bendix advance, which were around $70 for a set of fronts.
Yeah called up Mazda and they want a fair bit.
Where can I get the hawk hp+ for that much?
Caffeine
Postby Caffeine » Fri Feb 25, 2011 2:06 pm
jdimitri wrote:Where can I get the hawk hp+ for that much?
http://www.mx5mania.com/brakes.htm
Users browsing this forum: No registered users and 329 guests
