NA6 & NA8 Calipers & Pistons
Is it true that the front and rear pistons are the same size on both the NA6 & NA8.
- rossint
Re: NA6 & NA8 Calipers & Pistons
I've heard the NA8 calliper is slightly different to allow for the bigger pad but that both will work however you can get uneven pad wear using an NA6 calliper and NA8 pad. I've not seen any proof of it though.
Users browsing this forum: No registered users and 76 guests
