I am talking about the section starting with the circled hose here, and ending at the bottom radiator outlet
zossy1 wrote:Jerrah is right.
There are also several aftermarket hoses that fit. For example, Flyin Miata make a special one piece hose for turbo installations to route the hose away from the compressor.
jerrah wrote:EDIT: Not sure why you're asking on that other thread if the radiator hose needs to be fixed to the body. One end to the radiator is fixed, and the other to the engine which moves back and forth. It's not like the pipe flops around once the hose clamps are on.
mitch_f1 wrote:jerrah wrote:EDIT: Not sure why you're asking on that other thread if the radiator hose needs to be fixed to the body. One end to the radiator is fixed, and the other to the engine which moves back and forth. It's not like the pipe flops around once the hose clamps are on.
Yeh, I dunno, just thought it might be an issue. But I guess if it is reasonably thick rubber it shouldnt then?
