Lower/mid radiator hose union
mitch_f1
Postby mitch_f1 » Sun Feb 13, 2011 8:57 pm
I am still really worried about the proximity of my middle radiator hose to my headers. I have been looking at it, and without the air con compressor, there is a bit of room there, which makes me think, is it possible to run a single rubber hose from the water pump to the bottom of the radiator. It may need to be secured to the side at at least one location, but other than that can anyone see an issue in doing so? Has it been done before? Is there a reason for the middle radiator pipe, other than keeping the hose to the side, out of the way?
I am talking about the section starting with the circled hose here, and ending at the bottom radiator outlet
mitch_f1
Re: Lower/mid radiator hose union
Postby mitch_f1 » Sun Feb 13, 2011 9:19 pm
Found this, with useful pictures. Doesn't have a post-mod write-up though?
http://forum.miata.net/vb/showthread.php?t=404769
jerrah
Postby jerrah » Mon Feb 14, 2011 12:46 am
NB lower hose is one piece from pump to radiator. I fitted one this morning to my NA and threw away the metal pipe.
EDIT: Not sure why you're asking on that other thread if the radiator hose needs to be fixed to the body. One end to the radiator is fixed, and the other to the engine which moves back and forth. It's not like the pipe flops around once the hose clamps are on. :)
1991 MX5
zossy1
Postby zossy1 » Mon Feb 14, 2011 7:33 am
Jerrah is right.
There are also several aftermarket hoses that fit. For example, Flyin Miata make a special one piece hose for turbo installations to route the hose away from the compressor.
zossy1
Postby zossy1 » Mon Feb 14, 2011 7:36 am
zossy1 wrote:Jerrah is right.
http://www.flyinmiata.com/index.php?dep ... r=22-51000
Postby manga_blue » Mon Feb 14, 2011 10:31 am
When I put headers on I just wrapped the rubber hose from that joiner to the water pump in reflective tape. Likewise the heater hoses near the back of the headers. They've been good like that for a couple of years.
mitch_f1
Postby mitch_f1 » Mon Feb 14, 2011 6:37 pm
jerrah wrote:EDIT: Not sure why you're asking on that other thread if the radiator hose needs to be fixed to the body. One end to the radiator is fixed, and the other to the engine which moves back and forth. It's not like the pipe flops around once the hose clamps are on. :)
Yeh, I dunno, just thought it might be an issue. But I guess if it is reasonably thick rubber it shouldnt then?
zossy1
Postby zossy1 » Tue Feb 15, 2011 2:13 pm
Rubber is nice and flexy - no probs at all. :)
jerrah
Postby jerrah » Tue Feb 15, 2011 3:38 pm
When it's on the car it'll be full of coolant too which will force it to a shape as well.
1991 MX5
