Coolant reroute hose (formed pipe)
jerrah
Postby jerrah » Wed Feb 02, 2011 10:55 am
I found on miataturbo a formed coolant pipe that is an almost perfect fit for the MX5 coolant reroute.
Part number is: dayco e71989
http://www.miataturbo.net/showthread.php?t=46698
It was a bit difficult to locate in Australia being out of a GMC truck but Eagle Spares in springwood stocks them.
1991 MX5
gussy
Re: Coolant reroute hose (formed pipe)
Postby gussy » Wed Feb 02, 2011 11:58 am
Excellent find. :D
Locutus
Postby Locutus » Wed Feb 02, 2011 12:16 pm
whoa, that's awesome. thanks!
Uncle Arthur
Dodgy Award Benefactor
Postby Uncle Arthur » Wed Feb 02, 2011 12:56 pm
MX5 Plus in Brisbane also do an aluminium re-route pipe (hotside) which I used - with a couple of sections of flex hose it works just fine.
jerrah
Postby jerrah » Wed Feb 02, 2011 1:52 pm
Uncle Arthur I'm using the MX5plus spacer which outputs my coolant on the coldside? The rubber pipe has all the right bends around the intake - works well. :) I was previously using various bits of pipe and a piece of flex to do the bend. I was plagued with little leaks so one pipe all the way really sorts me out.
1991 MX5
gussy
Postby gussy » Wed Feb 02, 2011 3:36 pm
Uncle Arthur wrote:MX5 Plus in Brisbane also do an aluminium re-route pipe (hotside) which I used - with a couple of sections of flex hose it works just fine.
For 20 bucks?
Uncle Arthur
Postby Uncle Arthur » Wed Feb 02, 2011 4:05 pm
I didn't recall the OP stating a price.....
However - no - not $20 but then again if you are really balking at spending $ on your modded 5, you could always buy your own length of ally pipe at the right size and make your own.
jerrah
Postby jerrah » Wed Feb 02, 2011 4:10 pm
The pipe I bought wasn't $20 either. If you can find them cheaply in Australia let me know!
1991 MX5
