Excellent Polish: TR-3 Resin Glaze
Re: Excellent Polish: TR-3 Resin Glaze
Not too far from the gf. Keep me posted.
- RawSouth
- Szemen
Me too! =D
- RawSouth
RawSouth wrote:Ill grab one too if its not too much bother
Assuming you can get the one thats clear coat friendly? (The green tin I think)
Do you know if that is available?
ロードスター
Ah, I should mention clear coat version too for me.
- RawSouth
- Szemen
Whats minimum order?
- Steampunk
Guys, before you use it, read carefully what this product does, ie. it contains a cutting compound, so if your paint is very thin, it's going to cause more harm than good. From what I gather, it's aimed at paint that has tar, lime, etc strewn onto the paint so this gets it off effectively.
Ducati848 gave me a run-down after he used it, he used to be a detailer by trade so he knows what he's doing, worth sending him a PM.
Steve- it is the eternal search for the truly magic product which is better than all the other polishes but somehow has escaped the notice of the main stream. It will be the same as the rest and the before and after shots prove nothing- any good product will produce a result for a tired paintwork. Earlier in the thread there was also a reminder that one of the polishes was not suitable for clear coat finishes. Insofar as unique properties you are never going to get the formulae and it is probably like toothpaste claims.Remarkable that it has so many posts.
- bootz
Okibi, if you have any of these cans of magic polish left, I would like to have a go. Can pick it up at the next meeting whenever that it.
- bootz
Oh yeah, I just checked, its just finishing right at this moment. Maybe next time
- bootz
Okibi, as much as this website is a testament to superb programming, you haven't adjusted for daylight saving so the time is an hour out in WA.
So did you want some TR-3 lovin or you just gonna pick on my programming?
- edit - where were you looking, time on the front page of the site is correct by me.
- bootz
I'll take as much lovin as I can get but one can of TR3 will do me fine.
Programming wise this is a seriously well put together forum, I think the popularity speaks for itself, Its just that my posts read one hour ahead. i.e a post at 9 o'clock is time stamped 10 o'clock. I thought it might be the DS issue, hardly worth mentioning.
