ECU Pinout / Wiring diagram for NC (found)
- zombie
- Vehicle: Non MX-5
Does anyone know where I could get my hands on the ECU pinout details? I'm assuming there's no difference between NC and NC2 (2009+)
I will be (or more accurately, my workshop will be) doing a parallel install - let the aftermarket ECU handle fuel and timing, and the factory ECU handle everything else.
I don't know of anyone that has done this before on an NC so I'm hoping we don't run into too many obstacles, but the first hurdle to overcome is working out which wires to splice ourselves into
I can find plenty of wiring diagrams and ECU pinouts online for NA and NB but nothing for NC
Previous MX-5s:
Innocent Blue NB8A 10th Anniversary Edition
Stormy Blue NC2 Cosworth Edition
- Charlie Brown
Re: ECU Pinout / Wiring diagram for NC?
Try emailing Stephannie at stepht@bellengineering.net
or e-mail Xede on the Gold Coast.
Read here: http://www.bellengineering.net/articles.php?tPath=31_35
Hi Matt,
Stephanie is a good source, I have the Xede files at home that I can forward if you want.
Also have a map from her adjusted to Oz fuel that she has done for me.
Rob
- greenMachine
Interesting. Good on you for giving this a go.
What ECU are you proposing to use?
- zombie
- Vehicle: Non MX-5
Hello Sailor
Any and all information you can send me would be helpful as I've not found anything yet.
I have been told by several people that a "parallel" install will not work on the NC, and will lead to the loss of ABS etc, so I will probably abandon that idea and achieve the result a different way.
Either XEDE or a custom reflash; I will let you know. Stay tuned
Previous MX-5s:
Hi Matt,
That link to Corky's Begi page that Phil posted is well worth the look.
Hunt around the site, there's plenty of info on the Xede.
PM me you email and address and I'll forward the map and the install info that I have.
With your Cosworth on a road car, the Xede appears to be by far the best solution BUT it will not allow you to increase RPM over std.
I examined Haltec but the driveability was my doubt plus it's nearly twice the price.
BTW waht are those wheels and where did you buy?
Rob
- zombie
- Vehicle: Non MX-5
I've decided to go for a tuning solution by Moto-East - Mike Mann has spent many hours reverse engineering the MX-5 ECU (there are lengthy threads about it on the big forum - like this one) and has had much success tuning Cosworth cars including Faisal's (cyberbug)
He's cracked the RPM limiter too, although my NC2 already has a 7800rpm limit so I don't think I'll be going any higher than that.
The wheels are Gram Lights, by Rays Engineering - and I bought them right here, from a fellow forum member
Previous MX-5s:
Ahhh, looks like a good choice but with plenty of delays and shipping costs as you send your ECU back and forth
Rob
- zombie
- Vehicle: Non MX-5
Not so, you're confusing it with the DP tune, which was the other option I looked at. The Moto-East tune uses a box that connects via the OBDII port.
I also get software so that my local workshop can do the final tuning on the dyno, although Mike is able to do tuning from remote by emailing the maps back and forth, using data provided by a logger connected to the OBDII port.
Previous MX-5s:
- zombie
- Vehicle: Non MX-5
once upon a time, I wrote:I have been told by several people that a "parallel" install will not work on the NC, and will lead to the loss of ABS etc
I'd just like to say.. Bulldust!
As I mentioned in the Cosworth thread, I now have an Adaptronic e420c "Parallel" installed - it runs the injectors and coils, and the Mazda ECU runs everything else.
I got to go for a ride in my car today (the first time it has moved under its own power in over 4 months) and although I wasn't able to actually test them, there are no warning lights for ABS or anything else - and other than the drive-by-wire throttle being an absolute pain in the ass, all seems to be working well.
Anyway, to answer my original question that started this thread - the ECU pinouts for NC1 and NC2 (in Australia at least) are the same, and this is what I've been able to work out:
Code: Select all
Pin Function Pin Function Pin Function Pin Function
1A - 1AE - 2A Throttle Pos Sensor 2AE -
1B Starter Relay / Trans Range 1AF Brake Switch 2B Throttle Pos Sensor 2AF -
1C - 1AG - 2C Purge Solenoid Valve 2AG MAP Sensor
1D Clutch Pedal Pos Switch 1AH - 2D - 2AH Engine Coolant Temp Sensor
1E - 1AI HS_CAN_L Data Link 2E Oil Control Valve 2AI Generator
1F - 1AJ Accel Pedal Pos Sensor 2F - 2AJ Generator
1G - 1AK MAF Sensor 2G EGR Valve 2AK Throttle Pos Sensor
1H Fuel Pump Relay 1AL Accel Pedal Pos Sensor 2H EGR Valve 2AL Throttle Pos Sensor
1I Aircon Relay 1AM HS_CAN_H Data Link 2I Var. Tumble Solenoid Valve 2AM Camshaft Pos Sensor
1J Refrigerant Pressure Switch 1AN - 2J Var. Intake Air Solenoid Valve 2AN -
1K - 1AO Accel Pedal Pos Sensor 2K EGR Valve 2AO Throttle Pos Sensor
1L - 1AP Accel Pedal Pos Sensor 2L EGR Valve 2AP Throttle Pos Sensor
1M Cooling Fan Relay #1 1AQ Cruise Control Switch 2M - 2AQ Crankshaft Pos Sensor
1N Cooling Fan Relay #2 1AR MAF Sensor 2N - 2AR -
1O - 1AS Accel Pedal Pos Sensor 2O ? 2AS -
1P MAF Sensor 1AT MAF Sensor 2P Camshaft Pos Sensor 2AT Ignition Coil #4
1Q Main Relay 1AU Refrig Pressure Switch 2Q Rear O2 Sensor 2AU MAP Sensor
1R Cooling Fan Relay #3 1AV Accel Pedal Pos Sensor 2R - 2AV MAP Sensor
1S - 1AW ? 2S Camshaft Pos Sensor 2AW Ignition Coil #2
1T - 1AX Drive-by-wire relay 2T Power Steering Pressure 2AX Ignition Coil #3
1U - 1AY ? 2U Knock Sensor 2AY Engine Coolant Temp Sensor
1V - 1AZ Ground 2V Knock Sensor 2AZ Fuel Injector #4
1W - 1BA ? 2W Crankshaft Pos Sensor 2BA Ignition Coil #1
1X Trans Range / Neutral Switch 1BB Ground 2X ? 2BB Fuel Injector #1
1Y - 1BC - 2Y - 2BC Fuel Injector #2
1Z - 1BD Ground 2Z Front O2 Sensor 2BD Fuel Injector #3
1AA - 1BE ? 2AA - 2BE Rear O2 Sensor
1AB Brake Switch 1BF Drive-by-wire relay 2AB Crankshaft Pos Sensor 2BF -
1AC - 1BG - 2AC - 2BG Front O2 Sensor
1AD - 1BH Ground 2AD Front O2 Sensor 2BH Rear O2 Sensor
Previous MX-5s:
- zombie
- Vehicle: Non MX-5
Previous MX-5s:
- zombie
- Vehicle: Non MX-5
One last thing for anyone considering an ECU reflash. Be very careful to follow the instructions exactly and above all make sure your car's battery is fully charged before commencing.
Replacement ECUs are NOT cheap
Previous MX-5s:
- orx626
- Vehicle: NC - Rotary
zombie wrote:One last thing for anyone considering an ECU reflash. Be very careful to follow the instructions exactly and above all make sure your car's battery is fully charged before commencing.
Totally agree Zombie! In my experience I have found the re-flashing of RX-8 PCM's using aftermarket software (for FI) to be just a game of Russian Roulette.
BTW, NC's and RX-8's use the same PCM protocol(s).
Users browsing this forum: No registered users and 130 guests
