NB6 injectors same as NA6 ?
charlie_91
Postby charlie_91 » Fri Jan 07, 2011 6:05 pm
Hey guys im gettng a new engine for my car in the coming months for my turbo build and im just wondering if the nb6 motor injectors are the same as na6 ones ..
Charlie
jerrah
Re: NB6 injectors same as NA6 ?
Postby jerrah » Sat Jan 08, 2011 12:22 pm
AFAIK they're the same, they certainly look visually the same. My NB6 injectors were too clogged up to get the car to run properly so I dumped the original motors ones back in.
Won't you be running bigger injectors if you're going turbo and aftermarket ECU?
Also I thought the NB6 motor was missing the turbo oil feed, so you might need to take oil from elsewhere on the motor?
1991 MX5
Users browsing this forum: No registered users and 138 guests
