Either way, was my bad, too tired after the trip to Tsukuba to think this morning ;)
Boxer wrote:geofiz wrote:
$550 - Tokico Illumina 5 way adjustable shocks.
Keen on these as we're really happy with the springs in our car, where are they available from.
Also, where can you get the FM bump stops?
1red5 wrote:The Koni STR-T had unfavourable reviews over in the US forums. Steer clear.
Stick with Super Pro, ie. don't get too excited about getting harder bushes like Energy Suspension as they are bone-shakers.
My 2c: either get an entry level coilover set like BC or Yellow Speed, if your budget allows. Or go down same path as geofiz and many others and get "cheapy" combination. I found Eibach springs to be the cheapest reputable brand to buy online, and either Tokico or KYB adjustable dampers.
samx5 wrote:If the Koni Yellows have 3 positions for spring perches, does this mean I can lower my otherwise stock NB on the stock springs by the position of the spring perch? That is, I don't necessarily have to buy new springs to lower the car a bit when I replace the OEM shocks with Koni yellows? Maybe I need to see a pic to understand. Cheers, Mike
