Ok, who has one, what brand and do you actually use it to do a tune or just to keep an eye on your tune after the dyno or simply cause its blingy??
So are they worth having seeing any decent unit is $$$$$?
Terry
AFR gauges/ loggers
AFR gauges/ loggers
Re: AFR gauges/ loggers
Hi Terry, I use the Innovate gear - the LC-1 wide band which picks up AFR and the SSI-4 sensor interface which I mostly use to pick up RPM, TPS, and any combination of voltages from O2 sensor, MAF, IAT and ECT. AFR without RPM is not very useful. The setup has probably paid for itself 10 times over in not going to the dyno and picking up odd faults.
It plugs into a notebook behind the seat with a USB/serial adaptor. There are no visual displays. The notebook is connected only occasionallly. I only ever log runs because it's virtually impossible to read what's happening in real time - even before you start to think about the obvious safety issues. It serves 2 functions.
Firstly I run it occasionally to improve tuning, mainly checking AFRs at WOT across the full rev range. The easiest way is to do a few full runs from 1000 to 7000rpm in second. Logworks provides a lot of output analysis that I can use to finetune the fuel map. Comparing old logs shows performance gains and losses over time. It's easy enough to spot something which gives you a couple of 10ths from 60 to 100.
Secondly it helps for troubleshooting. I've picked up innacurate readings from the ECT, low voltages from the O2 sensor which are affecting fuel economy and some strange mixture fluctuations. These were the cause of performance problems for over 2 years before I finally picked them as power supply problems to the injectors and replaced the MAIN Relay. No way I would have ever worked that out without seeing the mixtures suddenly dive to 20+.
I have a innovate lc-1 hooked up to my ms pnp. I use it all the time to log and re-tune my fuel map. It works really well and is reliable.
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
- timk
Another vote for LC-1 here, hooks up via serial to my Adaptronic's 2nd serial port. Very tidy unit!
Just looking at different options,
http://14point7.com/SLC-Pure-Plus.php
looks interesting!!
Maybe even this SOB might be able to sort out the info
Terry
looks interesting!!
Terry
I'm looking at the Auterra Dash Dyno for my Cosworth build NC.
http://www.auterraweb.com/
Has the advantage of programmable lights that can be used as shift lights or knock, overboost,AFR out of range alarms.
Can also be connected to a GSP and give positioning data for trackwork analysis via things like Google Earth.
Enhanced functions for some vehicles including the NC MX5 that will give continuous AFR readouts etc.
Rob
Sailor wrote:I'm looking at the Auterra Dash Dyno for my Cosworth build NC.
Looks the goods, but can't use with standalone ECU!!!!
Be good if we could get some comments from Sean or Mr Rotary re AFR gear!!!
Terry
- Learner Driver
AEM have some good options too.
http://www.aemelectronics.com/wideband- ... phudi8d4a7
I use the serial output of the digital gauge connected to an Adaptronic ECU for logging / tuning.
Personally I wouldn't have an aftermarket ECU without fitting a wideband. If you want to understand what's going on with your engine and tune you really need to be able to log data under real driving conditions.
Ok, one for the guru's.
Been keeping an eye on these and now they have updated to an unit that can collect data etc.
http://14point7.com/SLC-Pure-Plus-2.php
Price seems right, just want some opinions from techno types
If I have read it right it would save having to drag out the useless laptop everytime I needed to log data, is that right?
Thoughts!!!!
Thoughts!!!!
- Tedsmx5
- Vehicle: NA8 - Supercharged
saboteur wrote:Another vote for LC-1 here, hooks up via serial to my Adaptronic's 2nd serial port. Very tidy unit!
+1
I have installed a Heat-Sink Bung Extender (HBX-1) - P/N: 3729 - #3729. As I have very high exhaust gas temperatures from my ceramic coated headers (causes my narrow band sensor to sh*t itself),
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
manga_blue wrote:Hi Terry, I use the Innovate gear - the LC-1 wide band which picks up AFR and the SSI-4 sensor interface which I mostly use to pick up RPM, TPS, and any combination of voltages from O2 sensor, MAF, IAT and ECT. AFR without RPM is not very useful. The setup has probably paid for itself 10 times over in not going to the dyno and picking up odd faults.
This, nothing else, I use the LC1 also, I log onto logworks or my aftermarket computers software, I dont have a guage, I read straight off the laptop with SOMEONE ELSE DRIVING, who is comfortable at WOT in 4th to redline. Used to tune my own car.
Users browsing this forum: No registered users and 146 guests
