13b renesis conversions available soon
Mr Rotary Qld
Postby Mr Rotary Qld » Thu Apr 29, 2010 1:14 am
Thanks for the info. any updates on the show if any would be great!
Thanks.
Mr Rotary Qld
Re: 13b renesis conversions available soon
Postby Mr Rotary Qld » Sun Nov 28, 2010 11:12 am
Just thought I will add some updated pictures....
Old Dude
Postby Old Dude » Sun Nov 28, 2010 1:29 pm
Nice job :)
cheers
Dale 8)
MX 5 2001 Grace Green
NB8B
RawSouth
Postby RawSouth » Mon Nov 29, 2010 7:47 am
Impressive, looks like its supposed to be in there!
ロードスター
Benny
Postby Benny » Thu Dec 02, 2010 1:32 pm
Looking at the pics, it looks as though there is enough room for a second engine!
Maybe even a 4 rotor?
Postby Okibi » Thu Dec 02, 2010 11:52 pm
mmmm 4 rotor !
Taz_
Postby Taz_ » Fri Jan 21, 2011 10:15 pm
Why not just spend about $25k and buy a used RX8?
I am sure you can pick one up for less than the cost of a conversion + NA/NB donor car.
Taz_
Postby Taz_ » Fri Jan 21, 2011 10:52 pm
Regardless of whether I would do this myself, thanks for posting up the end result and for doing the conversion.
Hopefully it works out for you on the business side.
Postby orx626 » Thu Feb 03, 2011 11:35 pm
Rxticle wrote:handles better!
Disagree on this one...you have my support on the rest! 8)
Mr Rotary Qld
Postby Mr Rotary Qld » Wed Feb 09, 2011 1:19 am
Rxticle wrote:Saw this in the metal today. Sensational work Tony.
Thanks and Good to know that you like it!
Are you thinking of going in this direction?
lukearama
Postby lukearama » Wed Feb 09, 2011 10:39 am
Is your mate Tony Stacey????? convicted Rotorphile... Arana Hills lad... Worked at Mazspeed virginia back in the day?? Had a big shunt in an RX4 once upon a time???
Apart from Mazda............ trust nothing else...
Postby orx626 » Wed Feb 09, 2011 11:04 am
lukearama wrote:Is your mate Tony Stacey????? convicted Rotorphile... Arana Hills lad... Worked at Mazspeed virginia back in the day?? Had a big shunt in an RX4 once upon a time???
That would be the same man. :P
Mr Rotary Qld
Postby Mr Rotary Qld » Wed Feb 16, 2011 8:39 am
You have recalled the past "lukearama", that was a long time ago!. what is your real name and how do you know me ????
Dan, you are quick on the replies but thats ok!. ( It will probably be Easter time before I reply otherwise! :roll: )
Looks like you have everything happening at your new shop! And I like all your new toys (cars)!
I may see you on Sunday at the show if I get the chance!
Mr Rotary Qld
Postby Mr Rotary Qld » Sat Mar 23, 2013 8:00 pm
My Renesis (RX8) / Rotary Engined NB MX5 (Miata) is now regretfully up for sale...
You can view it in the cars for sale section.
Thanks.
Orphan
Postby Orphan » Sat Apr 05, 2014 1:25 pm
Hey, do you have any pictures of how you mounted the engine and gearbox? At least from the NA conversions I have seen most have chopped up the stock subframe pretty extensively and used a modified oil pan but it looks like you may have been able to fit it in with engine mounts alone. I take it the NB has a taller transmission tunnel? Your swap looks really clean.
Users browsing this forum: madmort and 1 guest
