Stock fuel pump
- rs_simmo
Stock fuel pump
whats the boost limit you can run where the standard fuel pump will still flow enough to see good mixtures?
Mad Maz..
- rs_simmo
Re: Stock fuel pump
yeah sorry na6 eunos (if theres any difference between delivered and imported)
or rwhp would be a better figure
Mad Maz..
Re: Stock fuel pump
this should answer all those DIY turbo questions:
http://www.miataturbo.net/showthread.php?t=4288
- rs_simmo
Re: Stock fuel pump
93_Clubman wrote:this should answer all those DIY turbo questions:
thanks clubman
and woo!
300whp on a standard pump and reg
Mad Maz..
- Sean
Re: Stock fuel pump
There is no simple answer.
I know cars that made over 240rwhp on the stock pump and reg, yet I know other cars that stuggled at 200rwhp.
I suspect that it largely depends on how old and worn the pump is?
My recommendation would be to shell out the $250 odd and buy a drop in Walbro replacement GSS342 kit (from memory).
