I'm picking up an NB8A tomorrow, the only issue with it is this small tear on the soft top:
http://www.photoboxgallery.com/beckylou ... id=3003699
What's the best (easiest) way to fix it or should I go somewhere and get it done.
Or is it not worth fixing at all?
Also, I'm driving the car back from QLD to VIC, will gaffa tape suffice as a temporary solution to make sure it doesn't get bigger or leaks?
Best way to fix a small tear in the soft top?
- Old Dude
Re: Best way to fix a small tear in the soft top?
The Leather doctor/Vinyl doctor can probably do a permanent repair, I had a small hole and placed a piece of Boat canopy material from a trimmers jsut got an off cut and Put it on the inside with contact cement.
Check out the link it has some photo's of the repair
viewtopic.php?f=28&t=38628
Dale
Dale
MX 5 2001 Grace Green
NB8B
NB8B
fix it yourself- an offcut of vinyl glued on- try Clark Rubber .Patches look a bit tacky. An adhesive tape will not last long. Many MX5 drivers only put the top up when it pours ie it is a sports car. A new top - $800?
Can't tell if it's cut right through from pics, but unless you get a ultra sticky tape it's difficult to make it stick to inside or outside. As OD & MrM suggest sticking a vinyl patch on inside is best - may be you could do a temp one to drive home if it's cut right through.
- Learner Driver
Hi Guys,
I have a similar problem and I am looking for a decent vinyl repairer in Sydney. Does anyone know someone decent in Sydney?
- Learner Driver
sorry to bring this post again...
Where can I buy boat canopy material or a vinyl repairer in Sydney???
- Learner Driver
nobody in Sydney????
- Old Dude
You can buy boat canopy material from, Whitworths, but in all honesty if you go to a motor trimmer or better still a boat canopy manufacturer( boat trimmer)(Canopies) they will more than likely give you an offcut, or charge you a dollar or two. Also for Vinyl repair try "The leather doctor" there a mobile service and will come to you.
Dale
Dale
NB8B
NB8B
- Learner Driver
sweet... thx
Users browsing this forum: Bing [Bot] and 3 guests
