hello all, i currently have my turbo off getting a rebuild and my manifold getting a special coating (See links below). While the hot side of my engine bay is open i decided to replace a few parts that are getting a little long in the tooth.
The question i have is regarding the alloy line that runs from the heater core to the engine block. At the engine side of this alloy line is an o-ring seal (pictured) that pushes into the engine block. What is this fitting called? Should i replace this seal? Do they often leak?? Mine was very easy to pull out and push back in, is this normal? Where do you get them from?
Any info would be appreciated.. Shady
http://www.hpcoatings.com.au/
http://www.billetturbochargers.com/
"""Help needed""" Heater line seal
Re: """Help needed""" Heater line seal
Don't the exact name, but it's part of the heater return piping & it's not unknown that the o ring leaks, so I'd replace it given it should be a relatively inexpensive item & while access is easy. Also, the Mazda factory workshop manual recommends replacing when doing waterpump. Probably easiest & quickest to go to a Mazda dealer for the part.
For more info see here:
http://www.miata.net/garage/CoolingSystemProblems.html
http://www.miata.net/garage/waterpump-o-ring.html
http://www.miata.net/garage/water_pump.html
Gold information. I called my local dealership and they knew the part right away..
OE part number E30115287
$4.32+
Thanks Clubbie
$4.32+
Thanks Clubbie
no probs - good luck with the turbo rebuild as well.
