The older Bullet Roadsters with the 13BT rotary engine had engineers certification & were also road registerable. Over 300Hp too.
In this video the Bullet is compared to a turbo 1.6L MX-5, one that has been on this forum I think?
SuperMazdaKart wrote:Just save up the money & go Bullet Roadster. The ADR approved ones have 320Kw supercharged 4L V8 engines. That's 429Hp. Sure it only looks like an MX-5 without being one, but I'd assume it's own built chassis is fully up to the job & would probably do better then an MX-5 modded to run the same power.
nanotech wrote:Blue94t wrote:Deviant,
Problem is there is no way to legally run any LS engine in a MX5 in Vistoria.
Trust me I have been looking for a loop hole for 4 years now.
The only way to build a V8 MX5 that you can rego is to use the rover motor which just scrapes in for capacity.
YES! Finally someone actually understands. I've said this before but nobody seems to understand that v8 mx5's are NOT legal in Victoria. You won't get it passed and that's why in my opinion if you wanted to be different, go with an sr20det because you can at least have that engineered and on the road in Victoria. Yet nobody wants to listen. The same way rotary conversions aren't legal here.
FFS guys, you do the research. I'm happy to listen if you can prove to me that you can legally run an lsx in your mx5 or a 13b in Victoria
Gordo wrote:I was thinking if you wanted a 4.0 V8 BMW's M3 engine?
cost would be huge but stock it puts out 420HP
Gordo wrote:Just found out. 3.6L V8 that is in the 360 is around 18K with 12,000 miles on it
transmisson will set you back 7k
thats not bad 25K all up maybe 5-10 to fit for 30-35K you have a pretty quick car.
The 430 engine was only 22K bargin.
SuperMazdaKart wrote:http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&Item=220691773802&Category=130628#ht_1490wt_934
hrmmsss.
hrmmsss.
