Screeching from engine
- Mark.Pedlow
- Learner Driver
Hey when my engines cold and recently if i push it to hard when its kind of warm i get a screech from my engine bay anyone has this or know what it is?
Riding with my top down listening to my Jesus music
- Vehicle: Non MX-5
Re: Screeching from engine
Is your air con on when it happens?
- twinlol
This is usually caused by a loose belt.
A temporary solution is a spray can of belt grip, spray it on the possible offending belts such as the alternator belt, fan belt, AC belt, etc, etc.
- Mark.Pedlow
- Learner Driver
Im not to sure if its when the A/C is on or not why would that matter?
How hard is it just to replace the belts? how much?
Belt checking can be done pretty easily and they will not last forever. If the belt is loose as already stated it can slip and squeal. It may then be tightened but not excessively. A set of belts is about $50. A look at a something like a Haynes manual is useful - not sure if the owners manual mentions it. If one does want to do basic maintenance it is necessary to use a reference source. A Haynes would be cheap with the current Fx
Mr Morlock wrote:Belt checking can be done pretty easily and they will not last forever. If the belt is loose as already stated it can slip and squeal. It may then be tightened but not excessively. A set of belts is about $50. A look at a something like a Haynes manual is useful - not sure if the owners manual mentions it. If one does want to do basic maintenance it is necessary to use a reference source. A Haynes would be cheap with the current Fx
If you don't know of it, check out:
www.booko.com.au
I bought the Haynes and the 2 Rod's manuals (for the 1600 and 1800 - even though mine is a 1600) for not much more than the cost of just one here.
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
