Speed sensors - Type ?
Divo
Vehicle: ND - 1.5 GT
Postby Divo » Sat Oct 23, 2010 8:36 pm
Does anyone know if the MX 5 speed sensor is a hall effect sensor or an inductive sender sensor?
cheers
Divo
Re: Speed sensors - Type ?
Postby 93_Clubman » Sun Oct 24, 2010 1:04 pm
The 5 speed NA6 had the old style speedo cable & gear, but they changed over to electronic (hall effect I believe) in the 5 speed NB8A in '98 I think.
Postby manga_blue » Sun Oct 24, 2010 8:25 pm
Not sure about the NA6 but with the NA8 there's the old style cable into the instrument panel but then there's an output signal into the ecu from the instrument panel. This is very useful for fitting after market cruise control. Don't know whether hall effect or whatever tho. :oops:
gavin_eakins
Postby gavin_eakins » Wed Oct 27, 2010 3:27 pm
Divo wrote:Does anyone know if the MX 5 speed sensor is a hall effect sensor or an inductive sender sensor?
cheers
Divo
Inductive.
Cheers - Gavin Eakins,
Emerald, Victoria.
