Hi guys, taking my race car to the track for the first time on Monday
Got toyo r888 on her
What psi would you run in them on the way to the track
I know you would want no more then 30 psi hot when racing
But what about on the road to the track
Thanks to anyone that helps me with this
R888 what psi
- rwf
- Vehicle: NB Roadster
Re: R888 what psi
I put 28 cold in mine, drove to the track like that and it was never a problem. They have much stiffer sidewalls than normal road tyres so 28 certainly isn't a problem.
Re: R888 what psi
I have run my 195/50/15 R888 as low as 24psi. I do sprint events, so for track work 28 is probably a good starting point.
Si.
Si.
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
- rossint
Re: R888 what psi
I run mine 28psi cold to and from the track and 24 or 25 cold on the track. 28-30psi hot seems to be a good a good place to start.
- rwf
Re: R888 what psi
Thanks guys
Re: R888 what psi
Actually, is there an air line available at Lakeside for pumping them up? Might be good to go a little higher on the cold psi so that you can reduce the pressures to your preferred hot temp after the first session...
- rwf
Re: R888 what psi
I think there is at the garages
Re: R888 what psi
If you drive your car to the track on your motor sport tyres, a good rule-of-them is: cold pressure for road use = hot pressure for track use.
You can go as high as 32psi for the front axle (hot) and 30psi for the rear axle (hot). Any higher than this, bleed some pressure off.
Users browsing this forum: Google [Bot] and 2 guests
