I run hillclimbs at Collingrove pretty successfully in a standard motor NA6
There's one point of the circuit where I leave the car in 2nd cog on the revlimiter at 7200 for 2/3 seconds, rather than change into 3rd briefly and back to 2nd (which I've tried many times for no improvement.)
What would improve my times through this point would be being able to lift the rev limit (to approx 8000 ?)
I've done this previously quite successfully with a Renault SportClio 172, using a Unichip piggyback ECU
Is there something similar available for a standard NA6 motor ? Or any other suggestions ?
Many thanks
cheers pete
Raising NA6 rev limit ? with piggyback ?
Founder MX5 Club SA
Aust H'climb Class Champ 2005,10,12
Records Collingrove, Mt Panorama H'climbs in NA6
2015 CX3 AWD ,1990 NA
Re: Raising NA6 rev limit ? with piggyback ?
simplest way on the na6 is to use a different crystal:
viewtopic.php?f=44&t=23819&hilit=na6+rev+limit
- Guran
- Vehicle: ND - 1.5
Try a different diff ratio?
- StanTheMan
Keep the ratio you currently have. For hill-climb it's probably a better choice. I've had the crystal mod in my ecu for several years. IMHO . It's probably the best bet.
- StanTheMan
But if you want to rev to 8 k? Holy moly. Expect issues very soon unless you mod your internals.
- StanTheMan
The crystal mod......probably less than $3
Users browsing this forum: No registered users and 39 guests
