CAR IDLE ENGINE REVS
blackant
Postby blackant » Thu Oct 21, 2010 12:38 am
After 35mins driving, mix of traffic, all of a sudden the accelerator steps down a little and the revs climb to 1600rpm. They will stay there, intermittently dropping back to idle then returning back up to 1600rpm.
If you leave the car for a while and return everything is normal. Not related to fans coming on either.
Sensors or air intake?
Any ideas?
Thanks
fattima
Re: CAR IDLE ENGINE REVS
Postby fattima » Thu Oct 21, 2010 7:05 am
Presume you have an NA6 or 8? (Helps if you put this info when posting in the future)
http://www.miata.net/garage/KnowYourCar/S7_Idle.html
Search the forum too, it has been gone over heaps of times.
blackant
Postby blackant » Thu Oct 21, 2010 1:52 pm
Oversight.
1989 NA6 STANDARD INTAKE/EXHAUST
Revs are rising NOT dipping
gobsmax
Postby gobsmax » Thu Oct 21, 2010 2:41 pm
coolant sensor on back of engine block
Red '91 NA6 (R.I.P.)
Black '07 NC PRHT (R.I.P.)
Gold '98 NB8A (SOLD)
Soul Red '15 ND 1.5 GT
fattima
Postby fattima » Thu Oct 21, 2010 4:28 pm
blackant wrote:Revs are rising NOT dipping
Did you read the link properly, revs rise THEN dip. I've had it happen. Easy thing to check and a fairly common issue.
blackant
Postby blackant » Fri Oct 22, 2010 12:29 am
Fattima - Yes i did read it, something which you appear to be incapable of. The revs rise and never drop below idle CLEARLY STATED. This continues and is not related to being at a stop, again 'stop' is CLEARLY NOT MENTIONED. The 'link' is related to the idle, mentions taking your foot off the accelerator when I CLEARLY mentioned the accelerator actually moves in a downward direction. The 'ambient-mechanical' setting isn't relevant as I CLEARLY mention that it goes back to idle.
Thanks gobsmax, will start there.
fattima
Postby fattima » Fri Oct 22, 2010 7:03 am
Wow.
Enjoy chasing problems on your car, don't think you will find many people wanting to help you out with your attitude. So let me CLEARLY state that you are a hottie. :D
GP
Postby GP » Fri Oct 22, 2010 11:21 am
I've heard of the idle dip several times which mine does but I've never heard of your problem.
And I don't blame you for your retort, There's some stirrers on here like evrey forum :D
Graham
Users browsing this forum: No registered users and 32 guests
