Soft Top noises at speed
New seals?
Yes
1
25%
No
3
75%
Total votes: 4
Mark.Pedlow
Postby Mark.Pedlow » Thu Oct 14, 2010 10:56 pm
at about 100 km my NB gets a whistle from my door seals is it time for new seals or is that just the price of having at mx5 ?
Riding with my top down listening to my Jesus music
Mark.Pedlow
Re: Soft Top noises at speed
Postby Mark.Pedlow » Fri Oct 15, 2010 10:33 am
Both...
Locutus
Postby Locutus » Fri Oct 15, 2010 10:36 am
check to see if your tension cables are still intact - do a search if you're not sure what these are
BadBong
Postby BadBong » Fri Oct 15, 2010 11:19 am
I've had similar issues from the seals.
What I discovered was that when I folded the roof down that part of a seal was crested in a new fold-line that is different to the norm. Thereafter, everytime i put the roof back up, the seal would not cover all the gap between the actual roof and the top of the window.
The fix was literally to inspect the seals with the roof up to make sure that there's no gap and that the position of the seals look identical for both sides.
Once you've confirmed that they are in the right position, leave the roof on for a while (I left it on for a week) so that it's back to its original crest line.
