NSW - new suspension modification standards
rjastra2
Postby rjastra2 » Thu Sep 23, 2010 12:26 pm
Re: NSW - new suspension modification standards
Postby sliq » Thu Sep 23, 2010 4:57 pm
so we've got to advise the RTA?
seriously. those guys running the show are buffoons.
BadBong
Postby BadBong » Thu Sep 23, 2010 5:47 pm
"You must lower the height for both your front and rear suspension by the same amount...
Well, I've been meaning to ask.
How would the handling be affected if you lower the rear more than the front?"(or vice versa).
Given how low our rides already are on stock, anyone who wants to lower it even more would have trouble scrapping the bottom of the front bumper whenever they navigate over humps and bumps. But maybe if you lower the rear more than the front then it'll make it more 'livable'?
Charlie Brown
Postby Charlie Brown » Fri Sep 24, 2010 9:13 am
This was canned ages ago. :roll:
Old news. Look at the date - 2009.
There's a thread on it somewhere if you do a search.
philz
Wheel guru
Postby philz » Fri Sep 24, 2010 10:31 am
Please re-read the pdf... this is the latest draft :roll:
Charlie Brown
Postby Charlie Brown » Fri Sep 24, 2010 12:42 pm
philz wrote:Please re-read the pdf... this is the latest draft :roll:
Yes missed that one. :oops: Spotted the 2009 date and blind spotted (because my car was too low) the 2010 date.
Seriously though this draft is slightly better than the last one but still not great for us MX-5 owners. It is still mainly aimed at jacked up 4WDs.
The Pros:
Previously you couldn't fit coilovers or anything other than OEM release equipment. Now you can as long as you comply with the height restrictions, which for MX-5s will be the 100mm clearance. This means we will fall into the under 50mm lower category and be self certified.
The Cons:
Spring manufacturers will need to adjust the length of their springs to suit “trim” and ground clearance rather than a specific drop.
In other words King Springs will need to change the NC drop from 35/30 to 19/19, to maintain “trim” height and 100mm clearance. Other springs such as Mazdaspeed and Eibach can’t be used as they create an uneven “trim” height and give the NC a 90mm ground clearance.
Now to await the Final issue of these reg’s. :roll:
PS Love the reason that lowering the car effects your line of sight. :roll:
I'm over 6' but if you're too short the next thing they will do is ban you from driving because your line of sight is reduced.
GP
Postby GP » Fri Sep 24, 2010 1:04 pm
Lower an MX5 :shock: You would have to be mad :)
Graham
Postby Jeo » Fri Sep 24, 2010 3:30 pm
You's trollin GP
Overall, I'd say the pro's out weigh the cons for us.
Postby sliq » Fri Sep 24, 2010 5:07 pm
i think we're in a nanny state.
Charlie Brown
Postby Charlie Brown » Fri Sep 24, 2010 5:10 pm
sliq wrote:i think we're in a nanny state.
Make more rules. Saves fixing the roads.....and electricity.....and water........and taxes..............and........ sh*t it never ends with this lot does it?
6 months to go then years to fix it.
Users browsing this forum: No registered users and 233 guests
