NB 2001+ Sport brakes on NA - parts needed?
zossy1
Postby zossy1 » Thu Sep 16, 2010 9:08 am
Hi guys,
I am buying up parts to bring home for my NA8 and I have picked up a set of inexpensive 2001+ Sport calipers. I understand they are a direct bolt-on fit for the NA8. Here is what I got:
On the left is one of the front calipers, and on the right is one of the rears. I also picked up a set of 2001+ Sport rotors front and rear, and 2001+ pads front and rear.
My questions is, will I need anything else for the job? Are there any other mounting brackets I need? Will the standard lines mate up to these calipers? I was also thinking about buying a manual proportioning valve - a worthwhile investment?
Thanks guys!
Chris
Hellmun
Re: NB 2001+ Sport brakes on NA - parts needed?
Postby Hellmun » Thu Sep 16, 2010 11:54 pm
You need to cut up the dust covers and the proportioning valve is a definite requirement going off a mates car. Otherwise pretty sure they just bolt-on.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Fri Sep 17, 2010 1:25 am
You need to change the front brake hoses to the 2001 ones...they are different to the NA ones.
zossy1
Postby zossy1 » Fri Sep 17, 2010 8:43 am
^^ was going to wait to buy the new hoses until I get back to Oz, because I have heard that the lengths are different between the LHD and RHD cars - can anyone confirm this? The prices for lines aren't that much better over here in the US anyway...
Postby manga_blue » Fri Sep 17, 2010 9:13 am
Hellmun
Postby Hellmun » Fri Sep 17, 2010 9:36 am
Most of the time I've seen brake hoses for about $75 a line over here ADR approved. The 949 racing ones are $110 for all 4 from memory.
zossy1
Postby zossy1 » Sat Sep 18, 2010 12:29 am
Hellmun wrote:Most of the time I've seen brake hoses for about $75 a line over here ADR approved. The 949 racing ones are $110 for all 4 from memory.
OK, so if people are using the 949 Racing lines over here, then that means the LHD lines fit on our cars... can anyone confirm? I can get a full set of goodridge braided lines over here for $150USD!
