Crown Wheel & Pinion Ratio Identification
mazdatenfive
Postby mazdatenfive » Thu Sep 16, 2010 9:01 am
Does anyone know how to ID the various Mazda MX-5 crown wheel & pinion ratios.
I guess the number of teeth on each part is the starting point.
Would anyone of you knowledgable people like to elaborate on this. EG 4.1 has xx number of teeth on crown wheel & pinion has xx number of teeth etc etc.
greenMachine
Re: Crown Wheel & Pinion Ratio Identification
Postby greenMachine » Thu Sep 16, 2010 9:54 am
Is it in the car? If so, jack the rear up, secure one rear wheel, turn the other rear wheel once (or any number of complete, exact revolutions of your choice :lol: ), and count the revolutions of the propshaft. Can do it the other way if you like (turn prop shaft, count rear wheel revolutions). You will need some precision to ensure the result is accurate, which means a couple of people, and a tape measure to measure circumference of wheel and get accurate measurement of part revolutions.
If it is out of the car, yes just count the teeth and plug them into your calculator (big number divided by small number) if metal arithmetic is not your strength :wink:
:mrgreen:
mazdatenfive
Postby mazdatenfive » Thu Sep 16, 2010 12:37 pm
Thanks greenmachine, that is some very useful information to ID ratios but only for the gears in my possession.
I am also hoping someone can supply the tooth counts for the various ratios so as to confirm diff ratios for prospective purchases.
greenMachine
Postby greenMachine » Thu Sep 16, 2010 1:35 pm
Oh. :)
Sorry, can't help. Have you tried the big board, I'd be surprised if someone hasn't done this?
:mrgreen:
Rob E
Postby Rob E » Thu Sep 16, 2010 4:03 pm
Matty
Postby Matty » Sun Sep 19, 2010 12:20 am
mazdatenfive
Postby mazdatenfive » Sun Sep 19, 2010 6:17 pm
Great work Rob E & Matty, that's exactly what I'm after.
Users browsing this forum: No registered users and 47 guests
