NC - Sway Bars
- Vehicle: 10AE
NC - Sway Bars
Can someone please inform me of what the sizes are of the original (factory fitted) sway bars that are fitted to an NC? With thanks from slowpoke
- taminga16
Re: NC - Sway Bars
NC2 Sway Bars. Front. 23.5mm.
Rear. 11.5mm.
Greg.
Rear. 11.5mm.
Greg.
- Charlie Brown
Re: NC - Sway Bars
taminga16 wrote:NC2 Sway Bars. Front. 23.5mm.
Rear. 11.5mm.
Greg.
Hmmm, there's a spec. change.
NC1 Sway Bars
Standard
Front.......21.0mm
Rear........12.0mm
Whiteline
Front........24.5mm
Rear.........15.0mm
- Vehicle: 10AE
Re: NC - Sway Bars
Thanks for this useful info fellers!
- Vehicle: 10AE
Re: NC - Sway Bars
And what of the RX8's bars? I understand that they can be a good swap-over..? Any measurements known of these, please?
- Charlie Brown
Re: NC - Sway Bars
Come on slowpoke, don't make us do all the work for you. Use the search function.
And sure the RX-8 bars are a cheap swap but they aren't adjustable so you'll end up with understeer.
- Vehicle: 10AE
Re: NC - Sway Bars
I tried the SEARCH FUNCTION apropos measurements of the RX8' bars but no suitable matches could be found... But thank you for your reply.
- Charlie Brown
- Vehicle: 10AE
Re: NC - Sway Bars
Thank you Charlie Brown!
John
John
- orx626
- Vehicle: NC - Rotary
Re: NC - Sway Bars
With changes to other parts of my NC I've found the RX-8 sway bars (manual front & rear) to work extremely well on both the street and track.
Users browsing this forum: No registered users and 234 guests
