Why is my lil' Na6 running nice ? - Coolant sensor broken !!
kazjim
Postby kazjim » Mon Aug 30, 2010 9:23 pm
Hey all, got a strange one for you ....
Most mornings my lilttle Na6 with Loch Stewart intake is a little 'lumpy' and usualy stalls as i get to the end of my street .... no biggie ..
But i noticed on the weekend that the coolant sensor on the thermo housing was cracked and sitting 'loose' in the nut ..
Took it out, disconnected the wire and took it for a drive ... it runs nice :)
so, i started it this morning (cold start in Gosford ... a bit chilly) and it didnt stall !
So, i ask you ... what has happened, and should i bother fixing it !
havnt taken it for a long drive yet, so dont know if fuelling / Fuel usage has been changed
If my calculations are correct, when this baby hits eighty-eight miles per hour ... you're gonna see some serious s**t.
jerrah
Re: Why is my lil' Na6 running nice ? - Coolant sensor broke
Postby jerrah » Mon Aug 30, 2010 9:56 pm
Is it the front or the rear sensor that controls the fans?
1991 MX5
kazjim
Postby kazjim » Mon Aug 30, 2010 10:05 pm
Hmmm, I"m guessing the front one ...
its small, one wire and vertical... sits above the thermo housing :)
so, it only controls the fans ?
No worries then :)
Postby manga_blue » Tue Aug 31, 2010 1:15 pm
I'm not sure what the setup is on the NA6 but on the NA8 the engine coolant termp sensor (ECT) feeds a temp signal to the ecu. The ecu uses this to determine mixtures and to control the fans (among other things). If you disconnect the sensor then the ecu falls back to an assumption that the engine is a bit coolish and sets things a bit rich. Maybe if your ECT sensor had been feeding bad signals then the ecu may have been doing all sorts of things wrong and the fallback position is better, although you could now find fuel economy is awful. For my car I'd get a new sensor asap - about $90 from Mazda (ouch), unless someone knows of an aftermarket alternative that works (usually around $10-20).
jerrah
Postby jerrah » Tue Aug 31, 2010 2:12 pm
NA6 has two sensors. One for the fans and one for the ECU. The fan sensor controls the fans directly without ECU involvement AFAIK?
1991 MX5
jerrah
Postby jerrah » Tue Aug 31, 2010 4:53 pm
miataturbo.net seems to say the front one is the fan control. Are your fans still switching on?
1991 MX5
kazjim
Postby kazjim » Tue Aug 31, 2010 9:51 pm
Cant really say, been too cold here and I've only made short trips .... will know tomorrow - off to work in the city ...
Cheers all
Postby manga_blue » Wed Sep 01, 2010 12:37 am
jerrah wrote:NA6 has two sensors. One for the fans and one for the ECU. The fan sensor controls the fans directly without ECU involvement AFAIK?
Yeah, my bad, just checked the NA6 service manual, Jerrah. You're right. For the NA6 this is just the fan switch. NA8 is very different.
mazdatenfive
Postby mazdatenfive » Wed Sep 01, 2010 5:18 pm
I have a spare one of those sensors if you would like it, pm me.
kazjim
Postby kazjim » Wed Sep 01, 2010 9:43 pm
Well, funny story ....
So you know how today was a bit warmer ?
Guess who got stuck in traffic ?
It got a bit hot so hard-wired the fan switch to permanently on.....
saved the overheating i think, but I"ll be PM'ing MazdaTenFive any second now :)
Cheers all
meta
Postby meta » Fri Sep 03, 2010 7:15 pm
ironically, i have exactly the same problem and am after one of those thermo switches!!!
If anyone else has one pm please!
Thanks Meta
Red is best
kazjim
Postby kazjim » Sat Sep 04, 2010 8:57 pm
Picked up the sensor from MazdaTenFive this afternoon, will be fitted tomorrow ....
Thanks again, appreciate the help...
Free Bump for Meta !
Users browsing this forum: No registered users and 22 guests
