Wazman's NB8a
- wazman
Re: Wazman's NB8a
A little vid of me and a friends s14 silvia
http://vimeo.com/11987217
enjoy....... ( sorry i dunno how to embed vimeo...???)
ilovedrift.com
- zorak
Re: Wazman's NB8a
cool vid - this forum won't embed vimeo, only youtube
NB8A
WP 1:10.69
SMSP (south) 1:04.41
SMSP (GP) 1:53.98
WP 1:10.69
SMSP (GP) 1:53.98
- wazman
Re: Wazman's NB8a
TEASER.........drift at winton this weekend, dont want my car looking crap with stockies on the rear !
ilovedrift.com
- wazman
Re: Wazman's NB8a
The hydraulic hand brake turned out to be a nightmare ! well just bleeding the thing Because i mounted the slave UPSIDE DOWN in the tunnel under the car ! It had an air bubble in it that would not come out no matter how much i bled the system! I ended up unbolting the slave with the lines still attached and twisting it around until it was up the right way and then bleeding it ! That was really annoying because i was a smarty pants and mounted it in such a hard to get to spot
The lines are really easy to bend.....and didn't need to pay someone to pre bend them for me I actually needed to shorten them so i used a brake line flaring tool to do the job.
Below shows where i intend to "T" into the rear brake line. The slave has a valve in it so it just runs inline....
Below shows the lines going into the slave....more so how tight the space is there.... and close to my exhaust. high temps= brake fade.....installs heat shield !
This is how the leaver ended up looking .....ditched the ugly bolt The oem cover fits over it so mister po po dosn't bust my chops about it.
I also removed this piece of useless junk! The clutch line that goes over behind the engine and then back again to the clutch slave ! I just re-bent the remaining line to have just a straight metal only line from the top to the slave on the box= better pedal feel and simpler
Sportmax 002's 16x8 +0 after a trial fit it turns out my current wheels are -4 !!! not +4 like everyone seems to think...... the 4 mm extra clearance was obvious when i trial fitted the 002's...... Fitted pic's after "DRIFT ATTACK"
ilovedrift.com
Re: Wazman's NB8a
Hi mate, glad to see a dedicated drifter here. I am setting up my NA6 for drift also and would need lots of advices from you. Could you PM me your contact? Thanks.., Logan
Re: Wazman's NB8a
Ummmmm dude why are you selling mani n turbo??? Can you please take me for a drive before u take it off! I need some motivation to fit my kit hahah
get busy living or get busy dying
- wazman
Re: Wazman's NB8a
Driving home last weekend and booted it from a set of lights.......grabbed second.......POP ! crunch crunch grind grind !! sadface .....
no more second gear.....
out comes the box and apart it comes as "how hard can this be?" i think to myself !
im stuck here...... i need the service manual before i can continue safely...... anyone got a link ????
ilovedrift.com
- wazman
Re: Wazman's NB8a
Had some drift at winton raceway last weekend. Go Pro footage..........enjoy !
ilovedrift.com
- wazman
- wazman
- wazman
Re: Wazman's NB8a
5th gear one tails on the main straight ! linked the last corner of the esse's to turn one in one fish tail.....though i stuffed up in the spin footage above !
ilovedrift.com
Re: Wazman's NB8a
Nice work and great footage would have loved to see some from trackside too, looks like you were linking up those first few corners really well. Wish I could steer like that.
Re: Wazman's NB8a
The drifting is totally sweet - Keep up the good work !!!
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
- wazman
Re: Wazman's NB8a
I shall be at winton again this weekend ! for Performance Car Mania. Hopefully get some dry track drift footage for you guys.....
Hopefully be painting the car at the end of the year so there will be more updates soon.......at the moment spending alot of my cash driving the car rather than making it faster...... But i am still hungry for that 200rwkw so i can see my car getting rougher on the outside and faster on the inside.
ilovedrift.com
Users browsing this forum: No registered users and 31 guests
