I have a problem with my rear drivers side brake sticking on whenever I use the handbrake.
Has anyone encountered this and is there a fix.
I can always release it by hand but it means getting under the car and pulling on the handbrake cable.
Hand Brake Sticks On NA6
Re: Hand Brake Sticks On NA6
Sounds like you have the infamous 'slider pin' issue. The slider pins will corrode if regular maintenance is not undertaken. Here is a previous post on this very subject.
viewtopic.php?f=30&t=42278
and
http://www.miata.net/garage/ebrake/index.html
and
http://forum.miata.net/vb/search.php?searchid=4843116
J.
and
and
J.
Thanks Juffa. I think I can now get to work and fix sticking brake problem.
if it persists after greasing the slider pins then probably the pistons slightly corroded in the caliper.
i had that a few months ago, the slider pin was a bit ugly but also the piston was siezed on..mania had brand new genuine ones for half what i paid for a recondition,
if only i had known at the time
Users browsing this forum: No registered users and 260 guests
