Hand Brake Sticks On NA6
mazdatenfive
Postby mazdatenfive » Mon Aug 09, 2010 5:41 pm
I have a problem with my rear drivers side brake sticking on whenever I use the handbrake.
Has anyone encountered this and is there a fix.
I can always release it by hand but it means getting under the car and pulling on the handbrake cable.
Juffa
Re: Hand Brake Sticks On NA6
Postby Juffa » Tue Aug 10, 2010 12:47 pm
Sounds like you have the infamous 'slider pin' issue. The slider pins will corrode if regular maintenance is not undertaken. Here is a previous post on this very subject.
viewtopic.php?f=30&t=42278
and
http://www.miata.net/garage/ebrake/index.html
and
http://forum.miata.net/vb/search.php?searchid=4843116
J.
mazdatenfive
Postby mazdatenfive » Tue Aug 10, 2010 1:22 pm
Thanks Juffa. I think I can now get to work and fix sticking brake problem.
Postby 93_Clubman » Tue Aug 10, 2010 10:08 pm
if it persists after greasing the slider pins then probably the pistons slightly corroded in the caliper.
Chi3f
Postby Chi3f » Thu Aug 19, 2010 2:04 am
i had that a few months ago, the slider pin was a bit ugly but also the piston was siezed on..mania had brand new genuine ones for half what i paid for a recondition,
if only i had known at the time :oops: :x
mazdatenfive
Postby mazdatenfive » Thu Aug 19, 2010 11:04 am
Got the special grease. Now to get dirty.
Users browsing this forum: No registered users and 233 guests
