Si.G's NA6
ben wilson
Re: Si.G's NA6
Postby ben wilson » Thu Jul 08, 2010 11:01 pm
It might sound stupid, but try putting a plastic carbie style fuel filter in the line between the vacuum chamber and the MAP sensor. It should damp out a lot of the pulsing.
Si.G
Re: Si.G's NA6
Postby Si.G » Thu Jul 08, 2010 11:50 pm
ben wilson wrote:It might sound stupid, but try putting a plastic carbie style fuel filter in the line between the vacuum chamber and the MAP sensor. It should damp out a lot of the pulsing.
I have read that else where - I will give it a go, because it is being a nightmare to map.
Si.
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
Si.G
Re: Si.G's NA6
Postby Si.G » Sat Jul 17, 2010 1:24 am
My carb balancer arrive a couple of days ago. I had used the classic pipe in the ear technique to do the ITB balancing until now. For those who are thinking what is this guy talking about - it involves getting length of pipe and putting it down the end of each velocity stack, listening to the vacuum at the other end and then based on the noise making adjustments.
The pipe technique got things reasonably close, but now the ITBs are sync'd up, idle and initial throttle pick up are so much smoother now.
So if you have ITBs and no balancer, get one - for around $70 it is really worth it.
It is the next round of the sprint series that I compete in this weekend, so I should have some footage of the ITBs in action soon :D
Si.
NA6 B6T
red devil
Re: Si.G's NA6
Postby red devil » Sat Jul 17, 2010 10:58 am
where did you get the balancer from?
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
ben wilson
Re: Si.G's NA6
Postby ben wilson » Sat Jul 17, 2010 2:27 pm
I've been using one of these for years.
Si.G
Re: Si.G's NA6
Postby Si.G » Sun Jul 18, 2010 8:17 pm
red devil wrote:where did you get the balancer from?
I got mine from ebay, the one then ben has the line to above, looks good, especially if you don't have much room, mine is like this.
http://cgi.ebay.com.au/Carb-flow-meter-syncroniser-balancer-multiple-carbs-/270567650747?cmd=ViewItem&pt=AU_Car_Parts_Accessories&hash=item3eff16b5bb
Si.
NA6 B6T
Si.G
Re: Si.G's NA6
Postby Si.G » Sun Jul 18, 2010 11:04 pm
I have now given the ITBs a good run at the sprint today. It is the first time I have really floored the throttle through the gears. Just to be sure everything was okay, I did a bit of cruise mapping on the highway and gave the car a WOT run through 1st, 2nd and 3rd with data logging on just before I arrived at the venue. I added a bit of fuel in for WOT after the analysis at the RAC driver centre prior to the event starting.
Here's the vid of the best run - unfortunately my zorst is so loud that you cannot actually hear the ITBs that much, you can just hear like a sucking noise from them. I still have issues with part throttle, as you can probably hear - the throttle is like an on/off switch :D
I think I have taken a step forward today, I am about 1 second behind my buddy's S2000, his car is far from stock, but he runs the medium Yoko A050 in 225 and 245 width and I have the soft in 205. The soft compound will be worth some time, but still a result I am happy with.
Si.
NA6 B6T
broady
Re: Si.G's NA6
Postby broady » Mon Jul 19, 2010 1:25 am
Sounds great, man!
Also, I have the same gloves as you :P They're good, huh?
人馬一体 NA8
6/5/2010
Re: Si.G's NA6
Postby Okibi » Mon Jul 19, 2010 1:38 am
Sounds great Simon! You'll have to take us for a spin.
philz
Wheel guru
Re: Si.G's NA6
Postby philz » Mon Jul 19, 2010 2:15 am
wow the engine sounds soo good :mrgreen:
slug_dub
Re: Si.G's NA6
Postby slug_dub » Mon Jul 19, 2010 10:18 am
I'm with the others that the car sounds very very cool :D
I like all the fabrication work you've been able to do with building you're own bracing and other components, great work!
Si.G
Re: Si.G's NA6
Postby Si.G » Fri Sep 10, 2010 11:37 pm
After a bit of a break from car work, I have finally gotten around to hooking up my TPS. I have made a wiring adapter, so have not had to chop my stock loom.
I also had to re-wire may Megasquirt PNP so that the TPS signal goes out into the loom and is read. I was a little nervous doing the wiring, but now I have it all hooked up, there is a signal to calibrate in mega tune, so I am happy with that.
I now have to come up with a starting map for the Alpha-N tuning with TPS and then go through the whole tuning process again :roll:
NA6 B6T
Si.G
Re: Si.G's NA6
Postby Si.G » Sat Oct 30, 2010 11:45 pm
No real progress in terms of the car, other then it is leaking oil more than ever !!
But here are a couple of vids. First one is from the final round of the WA sprint series. I had already won my class so I decided to bolt on my Pirrelli P6000s for some fun.
This is from the raventech racing time attack battle last night. My times were not earth shattering, but I managed to get round the short track in less than a minute (which was my goal) - did a 59.993 on my last run.
si.
NA6 B6T
broady
Re: Si.G's NA6
Postby broady » Tue Nov 02, 2010 2:24 pm
Great vid Si :)
人馬一体 NA8
6/5/2010
Si.G
Re: Si.G's NA6
Postby Si.G » Tue Nov 30, 2010 12:04 am
Started the engine build today.
On stand ready to go.
End of day one.
-- Cams out
-- Sump off
-- water pump off
-- oil pump off
Generally the engine looks good inside and the bearings look good in the head, apart from one.
I am going to post a pic in the engine forum for discussion, it looks like it is casting issue. It was the first bearing I took off, and I thought the bearing had picked up and the engine was going to be dead, but all other look in great condition.
I will keep you posted on my progress.
Si.
NA6 B6T
Users browsing this forum: No registered users and 18 guests
