GP wrote:Yes but he said it's spitting water when WARM.
This is right GP, I wait until the engine has fully warmed up and still it spitting away. Tonight I might give it some rev's and see if the problem is just overflow in the muffer?
Guran wrote:Hmm, the plot thickens. Check the water under the radiator cap: it should be green and have no oily film on the surface. Also check the oil on the dipstick: it should be clean "oil colour" and have no sign of black goop or seperating liquids (oil and water don't mix). An oily film in the radiator and/or water on the dipstick, combined with water spitting from a warm exhaust, are signs of a failed head gasket. If that's the case, you should take it back to the Mazda dealer for a warranty claim. Pronto!
bruce wrote:Another sign to check - is your car using any coolant (does the level drop)?
Have someone start the car while you watch the exhaust pipe. Look for smoke. In general, a white cloud indicates water in the cylinders from a leaking head gasket or cracked block. If it pumps out great clouds of smoke, thank the owner politely and leave.
olboy wrote:Can you find where the noise is comming from
left or right side of the motor
Is it a tic tic, tich tich or sput sput noise
if its a tic then its internal
if its a tich then maybe a leaking head gasket out the side of the motor
if its a sput then maybe a leaking exaust gasket
Or it could be none of the above
Gordo wrote:olboy wrote:Can you find where the noise is comming from
Its a tic it sounds like its coming from the rear left of the engine, but when the car warms up it goes away. Wierd
mx51982 wrote:Sounds like tappers to me... As far as i'm aware, this noise is generally temperature dependent based on the thickness of the oil, but in theory it should go away when the cars warm up. Which doesn't make a whole lot of sense to me as one would assume such a noise would occur when oil is thin (car has warmed up), not when its thick, (car is cold). Correct me if i am wrong..
orx626 wrote:mx51982 wrote:Sounds like tappers to me... As far as i'm aware, this noise is generally temperature dependent based on the thickness of the oil, but in theory it should go away when the cars warm up. Which doesn't make a whole lot of sense to me as one would assume such a noise would occur when oil is thin (car has warmed up), not when its thick, (car is cold). Correct me if i am wrong..
The car is an NB8B...ie. does not have hydraulic lifters/lash adjusters (HLA's), it has solid lifters. Unless the engine has been apart and shimmed incorrectly there should be no tapping noise as what we experience with the HLA engines in the NA's.
Users browsing this forum: No registered users and 103 guests
