AVO/FM/BEGI
dorifta
Re: AVO/FM/BEGI
Postby dorifta » Sun Jul 04, 2010 4:21 am
Hrmm, wonder how much clearance there is for a flange adaptor plate n larger low mount turbo
get busy living or get busy dying
Re: AVO/FM/BEGI
Postby Okibi » Mon Jul 05, 2010 1:29 pm
Excellent advice.
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Mon Jul 12, 2010 12:24 pm
getting close. The instructions and parts from Begi are starting to give up and I am back and forth to Coventry's and Enzed for bits and pieces. Not long now!
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Thu Jul 22, 2010 5:45 pm
quick update
just waiting on a few more parts (both from the states and Mania).
Still got to put the underside bracing and trays back on. still to install the 255 Walbro.
Adaptronic is installed with EBC.
When (if) she kicks over I will then ship her off for exhaust and tune.
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Tue Aug 03, 2010 11:45 am
ahhhhhh poop!
cant get the bloody pump out. Cage is in the way.
Thinking about running an external 044 instead
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Wed Aug 04, 2010 7:00 pm
so just been reading the big forums and they seem to reckon the standard pump will do.
I cant get my head around it but it is something to do with the difference between pressure and flow.
So, if I am running adaptronic and 550cc, will I even need to change the pump?
realisitically I will not be going over 10psi
charlie_91
Re: AVO/FM/BEGI
Postby charlie_91 » Wed Aug 04, 2010 7:11 pm
no not neccessarily.. people will always say different things though.
there are plenty of people running this sort of setup with out fuel pump. make sure u have an upgraded fuel pressure regulator and u should be sweet with regards to fueling.
Like i said, other people may tell u differently but as it is.. 10psi isnt a great deal so power should be around 220 - 240 rwhp and that would be fine..
Read up even more if ur worried.
Hellmun
Re: AVO/FM/BEGI
Postby Hellmun » Wed Aug 04, 2010 7:52 pm
Two ways to have more flow. Increase the pressure using the fuel pump/RRFPR. Alternatively have bigger injectors that can flow more fuel with less pressure. Whether you need both depends on the amount of power it makes. Your tuner will tell you if you have to use a bigger fuel pump when the car starts to go higher in AFR as it makes power.
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Mon Aug 09, 2010 6:12 pm
Hellmun wrote:Two ways to have more flow. Increase the pressure using the fuel pump/RRFPR. Alternatively have bigger injectors that can flow more fuel with less pressure. Whether you need both depends on the amount of power it makes. Your tuner will tell you if you have to use a bigger fuel pump when the car starts to go higher in AFR as it makes power.
I have decided to take that advice. Thanks :D
Well I am very depressed. I got the adaptronic installed on the weekend. Turned the key first two notches- all good, everything lighting up (including adaptronic). Big yay!
Go for one more turn and the whole lot shuts down :cry:
So i do what every good home engineer does and crack open some beers and get a bit pissy pants whilst reading manuals. Leave the battery hooked up and it is flat within 24hrs.
Now I am the first to admit I know absolutely nothing about auto electrical.
I think it is time to put it on a flat bed and get it to a shop.
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Wed Aug 11, 2010 3:47 pm
I was waiting for someone to say "no Monza, don't do it. You have come this far. We beleive in you. You can dooooo eeeet"
:mrgreen:
Re: AVO/FM/BEGI
Postby Okibi » Thu Aug 12, 2010 12:28 am
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Thu Aug 12, 2010 12:49 pm
thanks Dave :mrgreen:
I think you are right. I will push on.
Waz man
Re: AVO/FM/BEGI
Postby Waz man » Thu Aug 12, 2010 8:07 pm
Monza, I think it would be great if you could do the whole job yourself but your previous comments are a little bit of a worry. Get it to a shop and get it sorted and running so you can join us on the black stuff for the first Autotest on the 29th. Keep going it is looking great and should be a terrific package. Warwick
Barb's Short 57.83 Long 70.45
Motorsport Manager of the MX5 Club of WA (11 years service)
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Mon Aug 16, 2010 12:05 pm
Sage words from Uncle Waz
Re: AVO/FM/BEGI
Postby Lokiel » Mon Aug 16, 2010 1:43 pm
1. Stand in front of a mirror
2. Raise your right hand
3. Turn you palm towards your head
4. Strike your left cheek with a sharp blow from your right hand
5. Point at yourself angrily in the mirror and say "THATS LOSER TALK!!!"
6. Get on with it.
This process has helped me on many an occasion.
