Dweezle wrote:If i get Koni yellows Adjustables and just reuse the King Springs it should be a pretty cheap exercise comparitivly.
Most seem really happy with that setup.
Really keen on these FM/FCM bumpstops. Makes complete sense to use these. As opposed to just cutting the standard bumpstops.
Koni + kings is very common and should work well, but couple of things to consider.
The springs are shorter than stock so you'll have less travel, so you might want to consider getting the FM or FCM top hats for the rear.
The FCM bump-stops are definitely the way to go. The standard ones will be shot and from thousands of accounts aren't in the same league as the FCM bump-stops.
