Borked wrote:Has anyone got a picture of these, showing the difference ?
Been advised the only difference between the two is "Sway bar mount with NB has a larger single mounting tab" and trying to figure out how that will affect me, if at all for using one in an NA...
AFAIK, the rears are identical. The fronts have the different ARB mounts, with the earlier 'U' mount preferred as it is stronger, and less likely to fail with heavier front bar.
