arghh im having second thought about selling my se kit!
i plan on upgrading ecus further down the track, do i thought instead of paying for labour to install emanage, tune ect ect ill just get a stock se ecu n leave it till i can get my hands on a microtec lt12 or something similar...
are se ecus compatible with the nb8a?
cheers in advance!
eddie
nb8a + emanage or stock se ecu?
get busy living or get busy dying
- timk
Re: nb8a + emanage or stock se ecu?
Lots of stuff is different, I think it would end in epic failure.
it has been done, but you might need to change the whole wiring harness... not worth the hassle and would be as expensive as putting the emanage on..
i am having the exact same dilemma as you , as i have the exact same turbo kit minus engine management sitting in my garage for the last 5 months....
Hrmmm.. How much are better are the Aurtronic ecus compared to the lt12s?
Is there an apexi power fc for us?
