Rear Hub axle nut torque settings
WASP
Postby WASP » Wed Jun 16, 2010 10:17 am
Hi I am replacing the rear axle/hub bearings on my NA 1800,I have searched for torque settings for the 29mm nut with varying results
ie 159-217 ft lb's, which sounds like a lucky dip. Can anyone be more specific.
Steve :?
Re: Rear Hub axle nut torque settings
Postby 93_Clubman » Sat Jun 19, 2010 3:08 pm
According to Haynes & Rod's manuals: 160-216
de Bounce
Postby de Bounce » Sat Jun 19, 2010 9:15 pm
WASP wrote:Hi I am replacing the rear axle/hub bearings on my NA 1800,I have searched for torque settings for the 29mm nut with varying results ie 159-217 ft lb's, which sounds like a lucky dip. Can anyone be more specific.Steve :?
Aim for a ball park figure of 190 ft lb
When you get up to this size bolt, the tolerance on correct torque can be quite large.
Assume you are using new nuts!
Motorkhana Video
