Na springs on NB ?
Na springs on NB ?
Postby hks_kansei » Thu Jun 17, 2010 4:57 pm
Simple thread, simple questions.
I've got a set of springs off an NA, will they fit my NB?
Just springs only, so it would be NB shocks, perches, tophats, etc. and Only NA Springs.
thanks.
Re: Na springs on NB ?
Postby Regie » Thu Jun 17, 2010 5:40 pm
im guessing they will fit..
as people say that NB springs on a NA the car will sit higher
i guess its the opposite
NA springs on a NB the car will sit lower than they would have on the NA
make sense?? haha i think i have confused even myself :P
stb
Postby stb » Thu Jun 17, 2010 9:38 pm
You'll have to check the spring end conditions. Comparing NA Bilsteins to NB Bilsteins the spring perches are different (NA flat both ends, NB flat only one end). I think this means it isn't a great idea.
philz
Wheel guru
Postby philz » Fri Jun 18, 2010 1:46 am
no they wont fit.
Postby 93_Clubman » Sat Jun 19, 2010 1:30 pm
as per philz & stb - spring ends are different, i.e. squared versus tapered spring ends.
Postby Regie » Mon Nov 15, 2010 7:43 pm
sorry to bring back a old thread..
but will a NB koni/King setup bolt up to a NA?
Postby 93_Clubman » Wed Nov 17, 2010 2:26 pm
Regie wrote:sorry to bring back a old thread...
factory shock & spring combo will if you use the entire combo & fittings, but from memory it will sit a little higher. so if you can compare the koni/ kings to factory nb shock & spring combo you should get a definitive answer.
