lightyear wrote:But now we are going to do forged bottom ends.
Me thinking the $15K budget is looking shaky....
Looking forward to seeing them finished though. Any idea of when you think they'll be on track...
rascal wrote:lightyear wrote:But now we are going to do forged bottom ends.
16bit wrote:
if you are also getting rid of the boot flooring then why not use some shrouded thermo fans and run active aero like the old brabham f1 cars to add some downforce.
lightyear wrote:You seem to know a bit about aero, but i will be doing much more than you suggest. As i think there is more to it than just a wing and splitter going by the info i have read. The rear diffuser won't work unless you have a flat floor to give un-turbulant air to it.
Jim Hall originally did this with his chapparal 2J in the Can-Am series back in the late 60s or early 70s. The size of the fans and the power required to run them meant using a separate engine (out of a snow mobile) to run them, and that was with the plastic side seals aroun the bottom of the car. It is also pointless to have this with a rear diffuser and undertray as you will just be creating low pressure between the car and undertray.
I think for the speeds you will be doing you don't need to get too carried away with aero. A good front splitter, rear diffuser and rear wing would be enough. With anything under 200 rwkw you would want too much rear wing either.
you would obviously have the fans sucking air between the floor and the road. if ferrari are doing it on the 599xx with no side skirts i would dare say it is effective.
i think you would want as much aero as possible as with the lower hp as you need every advantage you can get. not to mention that only running 225 section tyres on 15inch wheels and running up against cars with 265 section tyres and much larger wheels which have not only much wider but longer contact patches that have much more grip available.
also with such a massive reduction in weight there is going to be effectivley less mechincal griip available so it will be important to make it up aero grip. a similar principle to why the nissan gtr is so heavy - there is a good video on youtube from pistonheads.co.uk who interviewed the head engineer on why the car was so heavy.
i can't wait for this thing to be done. gonna be awesome!
are you going to do a fastback?
Users browsing this forum: No registered users and 206 guests
