Speed related knock - Wheel Bearing ????
Si.G
Postby Si.G » Fri Jun 11, 2010 10:22 pm
hi,
My car has started making a little knocking or scraping noise that speeds up with road speed.
I have had the car on the jacks and check the brake pads, and spun each wheel, typically you can feel a wheel bearing vibrating if you put your finger on the coil spring, but it also depends on whether it is the outer or inner race of the bearing that has the wear. I did not feel/hear anything on any wheel
I also had a look at the CVs and prop shaft and they look/feel fine.
I still think it is a wheel bearing, just wondering if anyone else can talk from experience and help confirm this diagnosis before I pull the car apart and go and buy a press.
Thanks Guys
Si.
NA6 B6T
Barbagallo Raceway : Long Track 67.394, Short Track 56.755
Si.G
Re: Speed related knock - Wheel Bearing ????
Postby Si.G » Sun Jun 13, 2010 8:08 pm
Solved
I have a badly flat spotted front tyre, must have done it a the last sprint event.
Ready for some new tyres anyway.
Si
NA6 B6T
Postby Okibi » Mon Jun 14, 2010 1:15 am
That'll do it, glad you found the problem pity it's not a cheap fix. You were planning on getting new tyres anyway weren't you?
project.r.racing
Postby project.r.racing » Mon Jun 14, 2010 9:42 am
put it on the rear, drop a big skid and make it round again. :D
deviant
Postby deviant » Mon Jun 14, 2010 12:50 pm
When I read your post I was going to ask if you had been on track and had a lock up. One of my road tyres has got a flat spot on it but nothing as bad as that! In fact you can barely tell where it is but you can definately hear it. It's not as noticeable now it is on the rear and I'm hoping it will wear out quite quickly.
Flipping annoying when I'm driving though...slap..slap..slap..slapslapslapslapdrrrrrrrrrrrrrr...
Si.G
Postby Si.G » Mon Jun 14, 2010 10:46 pm
Okibi wrote:That'll do it, glad you found the problem pity it's not a cheap fix. You were planning on getting new tyres anyway weren't you?
Yeap, needed new tyres, the R888s I have are all past the legal wear marker. I have gotten over a year of motorsport out of them, so happy enough.
Yoko A050 205/50/15 in soft compound are going to be ordered tomorrow :)
I know they are better than the R888, but hope I can get more that 2 events out of them :lol:
Si.
NA6 B6T
