AVO/FM/BEGI
Monza02
AVO/FM/BEGI
Postby Monza02 » Mon May 24, 2010 1:09 pm
Sean
AVO/FM/BEGI
Postby Sean » Mon May 24, 2010 11:14 pm
evil_weevil wrote:I spoke to Lee, managing directer of AVO out at superlap yesterday, and they are bringing in a basic turbo package.
With a piggy back ECU and extra injecter, they think it'll be under 3k for the full kit.
Its got me thinking... hehehehe
This kit is going to be a really nice set-up for people wanting a cheap kit thats MUCH nicer than the cheap non intercoolered greddy one.
They've been testing a while (I think I mentioned it in a post a while back) and have a very nice package together. Not sure on the compliance, but secondary injector set-ups should be very simple to pass. That said, dont forget that Australia is a small market as far as AVO MX5s go...
Monza02
AVO/FM/BEGI
Postby Monza02 » Mon May 31, 2010 3:09 pm
any one got any tips on how to get to the oil gallery sensor (under the intake manifold next to the filter)
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Tue Jun 08, 2010 8:33 pm
HELP
How do you actually drill the sump? The bit they gave me has a shank too thick to fit into a drill. No drill will fit into the gap between the sump and the chassis.
Anyone wish to share some wisdom?
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Wed Jun 09, 2010 2:48 pm
Ok so a mate is taking the drill bit to his workshop and cutting down the length and trimming the shank so it will fit in the drill.
I gather no one has actually drilled a sump while it is in the car
Waz man
Re: AVO/FM/BEGI
Postby Waz man » Wed Jun 09, 2010 4:08 pm
My origional AVO turbo application was drilled while the engine was in the car.
Looking back the mechanic told me he made sure there was no residule left in the sump but how would he really know. :evil:
Guess you could drain the oil a few times and run it through a stocking.
Barb's Short 57.83 Long 70.45
Motorsport Manager of the MX5 Club of WA (11 years service)
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Wed Jun 09, 2010 5:12 pm
not so worried about shavings. Just grease the bit and drain the oil. flush a few times with solvent.
More perplexed at how one gets a .57 inch shank into a drill with .5 inch max chuck and then runs it at right angle with only 250mm space between the sump and the chassis whilst the bit is 150mm long and a drill is 200mm long.
Hellmun
Re: AVO/FM/BEGI
Postby Hellmun » Wed Jun 09, 2010 8:18 pm
Never tried to do that as yet however can you undo the engine mounts and lift the engine up with a jack? Should get you some clearance from the cradle/steering rack if that's what it is in the way.
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Thu Jun 10, 2010 7:22 pm
If I was to do this again I would remove the donk and make life a bit easier :lol:
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Mon Jun 14, 2010 1:22 pm
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Mon Jun 21, 2010 12:04 pm
We're in business
A couple of the nuts were rediculously hard to put on. The EGR nut was a pain to get on the manifold. The exisiting exhaust does not mate up to the down pipe (no biggie as I was going custom anyway- on my rego I can get away with one muffler and no cat) so it is being held in place with a trolly jack.
My thoughts so far as it is a bloody well made piece of kit. I expected little pains like that described above but with a bit of persistence and beer everything can be done.
Over the week I will neaten up the loom in the engine bay and install the IAT and MAF sensors.
Next weekend I will finish off the oil and coolant feeds to the turbs and install the heat shields.
Then finish stripping the interior and install the ECU.
Woot! With tuning and exhaust I reckon I am about six weeks away from the track/road.
Monza02
Re: AVO/FM/BEGI
Postby Monza02 » Tue Jun 22, 2010 12:23 pm
dorifta
Re: AVO/FM/BEGI
Postby dorifta » Wed Jun 30, 2010 6:36 pm
Hellmun wrote:The SP manifold/turbo look significantly better for the fun side...but SE version keeps more options available.
how do you mean about the SE version? is the flange a more universal one? its not t2 is it?
get busy living or get busy dying
Hellmun
Re: AVO/FM/BEGI
Postby Hellmun » Wed Jun 30, 2010 11:53 pm
Just talking racing terms mate. An SE was mass produced and is elligible for much more racing. The SP only had about 100 made so it basically restricts you to 2B production sports and not sure what else. The SP setup should produce much more power though.
dorifta
Re: AVO/FM/BEGI
Postby dorifta » Thu Jul 01, 2010 11:21 pm
cool... what flange has the se manifold have?
cheers
Users browsing this forum: Google [Bot] and 103 guests
