Does anyone know what is going on with my MX5
It drives like crap when its cold
When I pull up at a set of lights the revs just drop to 500rpm and kicks back up to 850rpm where it should be then when I take off the revs just drops and comes back to life again :S
It idles at 850rpm
Drives like crap when cold
- TieNN89
- Vehicle: Non MX-5
the idle drop when braking sounds like the IAC valve.
How long do you allow it to warm up before driving?
- Regie
- Vehicle: NC - V8
mine was doing this a few weeks ago.
I ran some injector cleaner though it and it fixed itself
- TieNN89
not long
not even a minute
I try to let it run longer when I can though
Regie, what brand injector fluid did you use?
not even a minute
- Regie
- Vehicle: NC - V8
TieNN89 wrote:not long
not even a minute
good question, but i remember it was red and treated 2 tanks....i just put the whole bottle in
Engine coolant temp (ECT) sensor failure? ECU defaulting to engine hottish.
- Alex
Re: Drives like crap when cold
Idle dip?
http://forum.miata.net/vb/showthread.php?t=127446
http://forum.miata.net/vb/showthread.php?t=127451
- TieNN89
manga_blue wrote:Engine coolant temp (ECT) sensor failure? ECU defaulting to engine hottish.
Would this be the same sensor that tells me how hot it is on the instruments?
If so it looks to be working fine
It also idles higher when cold as normal
NA6 B6 engine used to have an extra sensor at the rear of the head, but from memory NA8 & NB8 BP engine just has the one sensor at the rear of the head.
