Hardtop weight
- Learner Driver
Hardtop weight
Hi
Just wondering if anyone knows the weight of the hardtop for a NA MX5
- Hammer
- hethro87
Hardtop weight
30Kg Alan?
I thought it was 20kg?
Maybe a careful balance on the old bathroom scales would be the trick!
Hethro
Hethro
NbA; Silver, Hardtop, Leather, K&N filter, Xenons, Mazdaspeed Muffler, Strut brace, Tiens, Slotted rotors, Sway bars & doof upgrade.
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
Hardtop weight
If you include the latches and cathces it is closer to 30kg's. About 26-27kg's from memory with everything.
- Hammer
Hardtop weight
hethro87 wrote:30Kg Alan?
Hethro
That's according to the book [Mazda MX5 Story] that I've read. Also the latter NB hardtop (with demister and additional roof trim/insulation) is heavier again.
The same book also states the NA softtop with plastic window is about 1kg heavier than the NB softtop with glass window.
- two40
Hardtop weight
That would be the difference in the frames?
Hardtop weight
wow don't know where your hardtops come from but mine on scales weighs 20kg and was nicely balanced by a 20kg counterweight when i had my hoist setup
- Hammer
Hardtop weight
Lightyear is correct, with all the additional latches etc the latter version is about 26kg all up. The earlier versions are about 1kg lighter.
The non-demistered/headlined version HT (only) is about 20kgs.
Hardtop weight
i have demister and the side latches(im assuming they are the additional ones). Maybe my lining is different but 5-6kg for different lining. must be special :p
- miata
- Vehicle: ND - 2
Hardtop weight
19.8 Kg including everything.
Moderator Qld.
Life Member MX-5 Club of N.S.W. #169
Waiter, I had the soup du jour yesterday and THIS ISN'T IT!
- Guran
- Vehicle: ND - 1.5
Hardtop weight
Clearly not all hardtops were created equal.
- Hammer
Hardtop weight
Clearly not. Is that why my car is so quite with the hardtop. All that extra headlining. Hmmm. migh have to rip some out. It could give me a few tenths @ Wakefield.
- lightyear
- Infinity & Beyond
Hardtop weight
I think the weight difference would be due to after market ones being different weight. I have seen a couple of different ones around. The wrecker near me has one with a leather texture finish even.
- miata
- Vehicle: ND - 2
Hardtop weight
lightyear wrote:I think the weight difference would be due to after market ones being different weight. I have seen a couple of different ones around. The wrecker near me has one with a leather texture finish even.
The textured finish is from the first model. The only colour was black and did not have a demister. The matching colours came later (90 or 91 from memory) and any headlining adds only a few ounces to the weight.
My '92 (October '91, the very first delivered in Oz with the wider rear number plate panel)) NA6b was delivered with matching Crystal White top and included the demister.
The weight stayed the same at 19.8 Kg.
Moderator Qld.
- lightyear
- Infinity & Beyond
Hardtop weight
Have you weighed the latches by themselves? they are heavy. You must have the lightest hardtop if yours weighs 19.8 complete. And you also have to include the clips on the car and the bolts.
Users browsing this forum: Google [Bot] and 153 guests
