Quick timing belt question
Postby Regie » Wed May 26, 2010 12:48 pm
I shall be attempting a timing belt change on my car next week. Done them before on mates cars, so hopefully all will go well.
Just a quick question. Does anyone have the tool for holding the crank while undoing the big nut (simialr to the tool in the service manual) Any chance i could borrow for a week? :)
if not is there any secrets as to getting the nut off?
Juffa
Postby Juffa » Wed May 26, 2010 1:28 pm
I found that by putting the car into gear, 5th I believe, then I could undo the nut. Just make sure the rear wheels are on the ground, hand brake is applied and the wheels are chocked so the car can't move. I used a large pry bar over the socket wrench to give me the leverage.
Have you worked out how to stop the cams moving when changing the belt?
J.
fattima
Postby fattima » Wed May 26, 2010 2:26 pm
Both times I've done a cambelt change I did as Juffa mentions, no problems. One I didn't need an extension the bolt just unwound with very little force :shock:
wun911
Postby wun911 » Wed May 26, 2010 2:51 pm
flyin miata sells the tool you want its like 30 bucks someone should buy it and cut out a template...
every ounce counts
Postby Regie » Wed May 26, 2010 4:39 pm
Juffa wrote:I found that by putting the car into gear, 5th I believe, then I could undo the nut. Just make sure the rear wheels are on the ground, hand brake is applied and the wheels are chocked so the car can't move. I used a large pry bar over the socket wrench to give me the leverage.
J.
ahh didnt think of that...it should do the job then
as for the cams moving...nup i got a week to think about it :P
fattima
Postby fattima » Wed May 26, 2010 4:52 pm
This method works a treat
from here
http://www.miata.net/garage/timingbelt.html
Postby Regie » Wed May 26, 2010 7:37 pm
fattima wrote:This method works a treat
from here
looks good enough for me!
StanTheMan
Postby StanTheMan » Wed May 26, 2010 10:16 pm
each to thier own. Whatever works for you.
But I found TDC on No 1
line up the marks works a treat.
Unfortunately with your NB8B you don't have the luxury of the marks you have with the non VVT models
But frankly I'd personally check the markings & final check with counting teeth. Maybe even mark the cam sprockets on the intake side.
Users browsing this forum: No registered users and 146 guests
