Boot Light
zombie
Boot Light
Postby zombie » Sun May 23, 2010 7:59 pm
a proper "boot light" wasn't added until (I believe) 2003
However if your turn your parking lights on, you will get light from your "license plate" lamps which hang down from the bootlid :D
Previous MX-5s:
Innocent Blue NB8A 10th Anniversary Edition
Stormy Blue NC2 Cosworth Edition
Boot Light
Postby Hammer » Sun May 23, 2010 8:27 pm
zombie wrote:a proper "boot light" wasn't added until (I believe) 2003
As Zombie mentioned, the rear plate lights double as the boot light on the NB8B. Though in my 2002, the moment I open the boot (either remotely or manually), the plate lights automatically turn on. I don't need to turn on the park lights.
AFAIK, the 2001 is the same as the 2002 NB8B.
Garry
Boot Light
Postby Garry » Mon May 24, 2010 8:48 pm
The bootlight switch was added mid 2001. It uses the number plate lights and the switch is part of the boot latch. It should be easy to add retrospectively if you can source a latch from a wrecked car.
