Wazman's NB8a
Wazman's NB8a
wazman wrote:Hey man, thanks. I should be driving........just had a few hiccups![]()
You'd better hope that the owner of that cat you've run over and skinned doesn't read this thread
Wazman's NB8a
wazza i will be at winton this week... not in my car tho
with bry
havnt got around to installing my turbz yet... flooded at work atm
get busy living or get busy dying
Wazman's NB8a
WOW!
was linked to this thread by Trent from STATUS tuning from SAU - just saw a few pages - awesome!
will have to read full thread later!
viewtopic.php?f=73&t=62834
- wazman
Wazman's NB8a
Drift practice again a few weeks ago at winton......
Tandem with my mate Rob in his s14 290rwkw !
ilovedrift.com
- wazman
Wazman's NB8a
Without good tyres on the rear i just ran to deep on corners and struggles to hit apex's. The second hand 15's did smoke good though
ilovedrift.com
- wazman
Wazman's NB8a
Im not happy with the way the car looks on track...... maybe not low enough ? or a front lip needed......
I need a decent set of spare wheels for the rear the stock ones look like poo
ilovedrift.com
- wazman
Re: Wazman's NB8a
A little vid of me and a friends s14 silvia
http://vimeo.com/11987217
enjoy....... ( sorry i dunno how to embed vimeo...???)
ilovedrift.com
- zorak
Re: Wazman's NB8a
cool vid - this forum won't embed vimeo, only youtube
NB8A
WP 1:10.69
SMSP (south) 1:04.41
SMSP (GP) 1:53.98
WP 1:10.69
SMSP (GP) 1:53.98
- wazman
Re: Wazman's NB8a
TEASER.........drift at winton this weekend, dont want my car looking crap with stockies on the rear !
ilovedrift.com
- wazman
Re: Wazman's NB8a
The hydraulic hand brake turned out to be a nightmare ! well just bleeding the thing
Because i mounted the slave UPSIDE DOWN in the tunnel under the car ! It had an air bubble in it that would not come out no matter how much i bled the system! I ended up unbolting the slave with the lines still attached and twisting it around until it was up the right way and then bleeding it ! That was really annoying because i was a smarty pants and mounted it in such a hard to get to spot
The lines are really easy to bend.....and didn't need to pay someone to pre bend them for me
I actually needed to shorten them so i used a brake line flaring tool to do the job.
Below shows where i intend to "T" into the rear brake line. The slave has a valve in it so it just runs inline....
Below shows the lines going into the slave....more so how tight the space is there.... and close to my exhaust. high temps= brake fade.....installs heat shield !
This is how the leaver ended up looking .....ditched the ugly bolt
The oem cover fits over it so mister po po dosn't bust my chops about it.
I also removed this piece of useless junk! The clutch line that goes over behind the engine and then back again to the clutch slave ! I just re-bent the remaining line to have just a straight metal only line from the top to the slave on the box= better pedal feel and simpler
Sportmax 002's 16x8 +0 after a trial fit it turns out my current wheels are -4 !!! not +4 like everyone seems to think...... the 4 mm extra clearance was obvious when i trial fitted the 002's...... Fitted pic's after "DRIFT ATTACK"
ilovedrift.com
Re: Wazman's NB8a
Ummmmm dude why are you selling mani n turbo??? Can you please take me for a drive before u take it off! I need some motivation to fit my kit hahah
- wazman
Re: Wazman's NB8a
Driving home last weekend and booted it from a set of lights.......grabbed second.......POP ! crunch crunch grind grind !! sadface .....
no more second gear.....
out comes the box and apart it comes as "how hard can this be?" i think to myself !
im stuck here...... i need the service manual before i can continue safely...... anyone got a link ????
ilovedrift.com
- wazman
Re: Wazman's NB8a
Had some drift at winton raceway last weekend. Go Pro footage..........enjoy !
ilovedrift.com
