I've done this.
Do you still need advise?
NC 2006 BOSE 6 stack Replacement
- IB1ZA
http://www.highclass.net.au/
- IB1ZA
Ok.
a) I brought the face plate from UK and I got screwed. It doesn't come with the brackets etc.
b) I brought a metra MX5 face it which comes with the face and the brackets from USA. the link is http://cgi.ebay.com.au/Metra-99-7506-20 ... 439d4e0441
c) System will connect easy and you will be able to use the factory bose amp and speakers
d) You can connect your MX5 controls by using the right add-on. Once you know which head-unit you want look around on google. It can be done by a input in the back of the unit which is a remote input or can be done by inferred.
- IB1ZA
- IB1ZA
Visit viewtopic.php?f=55&t=36974&p=502751&hilit=nc+stereo#p502751 for the photos
Are you in Victoria? I can provide you with a guy who can do the install %150 perfect.
- IB1ZA
Jolly Swagman wrote:Thanks for that, looks impresive! I live in the Northern Territory about 2,500 klm from St AlbansIf you could point me in the direction of the wiring and head unit that was successful for you, there's a good chance I could install it my self. Otherwise, there is a possibility my wife could be driving down to Melb in 4 weeks. Does your installer do this for a living, or is he just a mate?
Hi Mate,
I'm not sure about the way the wires work. You may want to check other maita forums for this one.
The installer is a pro. He also did a headunit replacement in a RX8 for me which is very rare.
- IB1ZA
His name is Chad
0413-995-496
Make sure you get the metra kit that I showed you on ebay. It is perfect for the install.
0413-995-496
