Subaru Upper Engine Cleaner review...
Andrew
Postby Andrew » Sun Apr 25, 2010 7:40 pm
All done and everything went well.
I'm a little disappointed that we didn't fill the street with smoke although that is good I suppose :mrgreen:
I also put replaced the old Iridium plugs with some new ones along with changing the oil and all seems to be running very throughout the entire rev range.
Funny thing was whilst using the Subaru cleaner my car started to sound like a Subaru boxer engine :) -
Postby Okibi » Sun Apr 25, 2010 7:45 pm
Not much smoke at all! Thanks for taking the time to video it. So you give this product the thumbs up?
Andrew
Postby Andrew » Sun Apr 25, 2010 7:50 pm
Okibi wrote:Not much smoke at all! Thanks for taking the time to video it.
No worries :D
Okibi wrote:So you give this product the thumbs up?
Yes.
I will have to take the car for more of a drive tomorrow and see how it performs, a cold start will also be interesting.
Even prior to the oil and changing the plugs the engine felt alot smoother and idled better.
Postby Hammer » Mon Apr 26, 2010 7:06 pm
green_comet wrote:These are the instructions on the can, bring the car up to running temp, then turn it off. Spray half of the can into one of the lines going to the manifold.
I'm assuming I use the same intake to the manifold for the NA8 as showned on this NB photo?
marcusus
Postby marcusus » Thu Apr 29, 2010 7:55 pm
I just bought a can of the stuff. I'll give it a go on the weekend when I can get a hand doing it (the whole putting the stuff in the engine at the same time as keeping the engine alive sounds challenging if doing it alone).
Dweezle
Re: Subaru Upper Engine Cleaner review...
Postby Dweezle » Thu Apr 29, 2010 8:03 pm
marcusus wrote:I just bought a can of the stuff. I'll give it a go on the weekend when I can get a hand doing it (the whole putting the stuff in the engine at the same time as keeping the engine alive sounds challenging if doing it alone).
Not really, I just grabbed the throttle with one hand and sprayed with the other.
That said, an extra person will make it easier again.
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
marcusus
Postby marcusus » Thu Apr 29, 2010 8:37 pm
Dweezle wrote:Not really, I just grabbed the throttle with one hand and sprayed with the other.
:facepalm:
That'll do it. Then again, I was also going to clean my air filter whilst I was at it, so having some company whilst I wait around for it to dry won't go astray.
Postby sliq » Fri Apr 30, 2010 12:10 am
that's an NA but with crinkle coated cam cover
marcusus
Postby marcusus » Fri Apr 30, 2010 12:54 am
Oh yeah, Andrew, which hole did you use to put the cleaner through?
Andrew
Postby Andrew » Fri Apr 30, 2010 10:17 am
marcusus wrote:Oh yeah, Andrew, which hole did you use to put the cleaner through?
The one that goes to the brake booster :D
Make sure you post a video as well :mrgreen:
marcusus
Postby marcusus » Sat May 01, 2010 12:19 pm
Andrew wrote:The one that goes to the brake booster :D
Hmmm... I don't know which one that is :oops:
I'll try and remember to do some video. I'm currently without camera, and the camera on the phone is rather rubbish.
Andrew
Postby Andrew » Sat May 01, 2010 3:21 pm
marcusus
Postby marcusus » Sat May 01, 2010 3:35 pm
Cool, thanks :mrgreen:
I suppose it's 50/50 really isn't it? :P
Andrew
Postby Andrew » Sat May 01, 2010 4:19 pm
marcusus wrote:Cool, thanks :mrgreen:
yep.
SuperMazdaKart
Postby SuperMazdaKart » Sat May 01, 2010 6:40 pm
These two locations are also good, right after the throttle body. Probably end up with a better amount of the cleaner to the individual cylinders & more of the intake manifold will get cleaned too.
Throttle body cleaner spray also will do the same job as the Subaru stuff.
