Battery size
evil_weevil
Battery size
Postby evil_weevil » Sun Apr 18, 2010 6:22 pm
Hey guys,
my battery died as car been sititng since december in garage!
I went to repco, got a replacemet, same ampage etc, put them next to each other and same size.
however for some reason as I go to fit it, the clamp now wont go over it, tired many times (or am I just a 'tard?)
any chance someone can measure their battery or know the dimensions so I can take it back and get a proper sized one?
cheers
Chris
viewtopic.php?f=73&t=62834
Battery size
Postby Mr Morlock » Sun Apr 18, 2010 7:12 pm
there are lots of posts on this subject- best advice is use the right battery - you cannot safely use a standard battery and some sellers have no idea of the right type and spec. Try as a search "mx52nv 9/11/08 " There is a stack of info and as Benny says you are far better off using the right one which lasts for many years.
wun911
Battery size
Postby wun911 » Fri Apr 23, 2010 2:33 am
Dimensions of stock panasonic battery (cm) is W12.5 H16.0 L 23.5
And just incase you wanted to know its 9.514 kg
every ounce counts
Battery size
Postby sliq » Fri Apr 23, 2010 8:33 am
supercharge gold
Battery size
Postby 93_Clubman » Fri Apr 23, 2010 12:41 pm
wun911 wrote:Dimensions of stock panasonic battery (cm) is W12.5 H16.0 L 23.5. And just in case you wanted to know its 9.514 kg
sliq wrote:supercharge gold
MF43: 235x170x135 (LxHxW)
or
MF40B20DF: 195x202x128 (LxHxW)
From memory, both are slightly heavier than Panasonic, but it's on their website.
Battery size
Postby sliq » Sun Apr 25, 2010 7:39 pm
the supercharge comes with 3 years warranty.
make sure you buy from a good, reliable auto-electrician. who will actually make the effort to charge your battery :roll: /or buy a trickle charger if your car is going to be just a weekender :wink:
